04-26-2015 01:47 PM - edited 03-18-2019 04:23 AM
HI,
I get this in hex
07 DF 04 1A 0D 15 3B 00 2D 04 00
in response to
SNMP OID=.1.3.6.1.4.1.9.9.156.1.2.1.1.8 (walk)
It is ccmPhoneTimeLastRegistered (date and time)
How to I convert?
04-26-2015 08:09 PM
This is Video Over IP, and you have already posted this in plenty other communities, please DO NOT duplicate posts.
04-26-2015 08:14 PM
Do you have a solution?
07-24-2015 01:10 AM
This post explains it fairly well: https://supportforums.cisco.com/document/52171/cts-system-snmp-decode-dateandtime
It is for a different object but it uses the same SNMPv2-TC DateAndTime standard.
The same info can be found in the description on the SNMP Object Navigator, though the post above is a bit clearer:
