snmp hex to decimal help
idurrani1
HI,
I get this in hex
07 DF 04 1A 0D 15 3B 00 2D 04 00
in response to
SNMP OID=.1.3.6.1.4.1.9.9.156.1.2.1.1.8 (walk)
It is ccmPhoneTimeLastRegistered (date and time)
How to I convert?
Jaime Valencia
This is Video Over IP, and you have already posted this in plenty other communities, please DO NOT duplicate posts.
java
if this helps, please rate
Do you have a solution?
bezcomservices
This post explains it fairly well: https://supportforums.cisco.com/document/52171/cts-system-snmp-decode-dateandtime
It is for a different object but it uses the same SNMPv2-TC DateAndTime standard.
The same info can be found in the description on the SNMP Object Navigator, though the post above is a bit clearer:
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&typeName=DateAndTime
