04-24-2017 12:16 PM - edited 03-18-2019 01:02 PM
After I upgraded my SX80 to 8.3.1, we now have a "Touch panel required" error message on the screen that will not go away. What is the fix for this? Downgrade to previous software version?
Thank you.
Solved! Go to Solution.
04-24-2017 12:20 PM
It's a bug and is fixed in CE9, or downgrade to CE8.2 if upgrading isn't an option. It's also mentioned in a recent thread: ce83-screen-shows-touch-panel-required-error-home-page.
04-24-2017 12:20 PM
04-24-2017 12:21 PM
Thanks Patrick.
