Technical question --> VCS-C et VCS-E
Louis-Alex
I have two cti-vcs-contrl-k9 and one cti-vcs-express-k9.
I was wondering if I can install additional PSU into the device, to assure a certain redundancy ?...
Patrick Sparkman
It's not possible to alter the hardware.
I recommend though you migrate you're old VCS appliances to virtual, the part numbers are:
  • VCS Control: R-VMVCS-C-M-K9
  • VCS Expressway: R-VMVCS-E-M-K9
Patrick Sparkman
