07-29-2016 06:01 AM - edited 03-18-2019 06:12 AM
Guys,
Im trying to change the SNMP community string for a Conductor entered into TMS, as its incorrect.
All my other devices allow me to change the SNMP string but for the conductor it is greyed out and I cannot edit it.
They system is moaning the SNMP String is wrong (Which it is) but wont let me change it.
I dont want to delete and re-add the conductor as it has various settings I'd like to keep.
Has anyone else experienced this?
Solved! Go to Solution.
07-29-2016 01:20 PM
It's not possible to update the community name from the Settings tab for Conductor within TMS, however you can change the community name on the Connection tab.
07-29-2016 01:20 PM
03-15-2021 02:13 AM
Yes it is possible:
Settings found in Administrative Tools > Configuration > Network Settings
This is a comma separated list of common SNMP community names Cisco TMS will use when discovering and adding systems to Cisco TMS. If you use a customized SNMP Community Name on your existing systems, be sure to add it to this list.
12-18-2018 06:49 AM - edited 12-18-2018 06:50 AM
