01-08-2019 05:58 AM - edited 03-18-2019 02:33 PM
I have problem relate upgrading firmware for SX20.
CRITICAL: Valid Release Key
How can I resolve this ??
01-08-2019 09:44 PM
If you have tc6.x release key and you are trying to upgrade tc7.x then it will be a issue and you will get the error " invalid release key"
For upgrading to tc7.x you need release key for tc7.x and then it will work properly.
And downgrading to tc6.x again, please try a factory reset and then try again putting the release key and see if it works.
Please rate if it is helpful...
01-09-2019 06:44 AM
There is no TC7 release key, Cisco stopped requiring release keys after TC6. My guess is you might have used the wrong software, if you had a valid TC6 release key for the crypto software package, and then installed the non crypto package (the difference is the "nc" before the number 6 in the file name), you will get a release key error. Likewise you can't install the nc TC7 if you have a release key for the crypto TC6.
So for TC7, download and install
s52011tc7_3_16.pkg |
Not
s52011tcnc7_3_16.pkg |
