12-05-2017 07:03 AM - edited 03-01-2019 06:26 AM
I upgraded UCSD to 6.5.0.1, build 65900 last week, and since then I have lost connectivity to my two Isilon clusters which are running 7.2.1.5
The isilon connectivity has previously been fine, and the credentials or any other connection details have not changed. I can resolve and ping the clusters from the UCSD shell though so there is connectivity.
The error I get is "Failed to establish connection with the device". Tailing the infrastructure logs gives me the following
2017-12-05 15:00:52,012 [ORR-InfraMgr:93B0F5F166] INFO run(OperationRequestReceiver.java:38) - Received operational request, added to queue.
2017-12-05 15:00:52,012 [ORP-1-17] INFO run(OperationRequestProcessor.java:77) - Executing request... requestId=1511; opName=doFormSubmit
2017-12-05 15:00:52,014 [ORP-1-17] INFO doFormSubmit(APIProvider.java:1227) - FORM SUBMIT AccountsFeature.forms.physical.account.modify
2017-12-05 15:00:52,019 [ORP-1-17] INFO definePage(FormBindings.java:798) - Field = EMC Isilon Clustergeneric.props.id.podName, LovProviderName =
2017-12-05 15:00:52,019 [ORP-1-17] INFO definePage(FormBindings.java:798) - Field = EMC Isilon Clusterspecific.props.id.policy, LovProviderName =
2017-12-05 15:00:52,020 [ORP-1-17] INFO definePage(FormBindings.java:798) - Field = EMC Isilon Clusterspecific.props.id.protocol, LovProviderName =
2017-12-05 15:00:52,020 [ORP-1-17] INFO definePage(FormBindings.java:798) - Field = EMC Isilon Clusterspecific.props.id.apiVersion, LovProviderName =
2017-12-05 15:00:52,020 [ORP-1-17] INFO validatePageData(PhysicalAccountEditForm.java:198) - Tanfield Datacenter
2017-12-05 15:00:52,020 [ORP-1-17] INFO validatePageData(PhysicalAccountEditForm.java:203) - Tanfield Datacenter
2017-12-05 15:00:52,028 [ORP-1-17] INFO validatePageData(PhysicalAccountEditForm.java:321) - after settingTanfield Datacenter
2017-12-05 15:00:52,036 [ORP-1-17] INFO handleModifyAccount(AbstractAccountHandler.java:144) - modify account to system
2017-12-05 15:00:52,056 [ORP-1-17] INFO getPodType(PodModel.java:87) - Getting pod type for datacenter Tanfield Datacenter
2017-12-05 15:00:52,059 [ORP-1-17] INFO getPodType(PodModel.java:99) - Pod type of the datacenter is GenericPod
2017-12-05 15:00:52,059 [ORP-1-17] INFO canAddComponentToDC(DatacenterLicChecker.java:372) - Checking add component for GenericPod,2,Tanfield Datacenter,EMC Isilon Cluster
2017-12-05 15:00:52,059 [ORP-1-17] INFO getPodType(PodModel.java:87) - Getting pod type for datacenter Tanfield Datacenter
2017-12-05 15:00:52,062 [ORP-1-17] INFO getPodType(PodModel.java:99) - Pod type of the datacenter is GenericPod
2017-12-05 15:00:52,062 [ORP-1-17] INFO getActiveCount(DatacenterLicChecker.java:348) - The license byte code 77
2017-12-05 15:00:52,141 [ORP-1-17] INFO canAddComponentToDC(DatacenterLicChecker.java:408) - Active count 24
2017-12-05 15:00:52,145 [ORP-1-17] INFO canAddComponentToDC(DatacenterLicChecker.java:413) - Max count: -1
2017-12-05 15:00:52,145 [ORP-1-17] INFO canAddComponentToDC(DatacenterLicChecker.java:437) - Pod Limit is good (24)
2017-12-05 15:00:52,172 [ORP-1-17] INFO isLimitOK(LimitTracker.java:447) - No limit check policy available for code 77 using default enforcement
2017-12-05 15:00:52,204 [ORP-1-17] INFO postAuthenticate(EMCIsilonAPI.java:764) - Time taken to process request https://xx.xxx.xxx.xx:8080/session/1/session : 6 millsec
2017-12-05 15:00:52,204 [ORP-1-17] INFO doTestConnectivityForModify(AbstractAccountHandler.java:349) - status.isConnectionOK() :::::::false
2017-12-05 15:00:52,244 [ORP-1-17] INFO sendNotificationEmail(EmailPolicyNotificationEmailSender.java:49) - Send email option is disabled : false
does anyone have any ideas?
Gary
12-05-2017 09:27 AM
I would open up a TAC ticket. THX.
