3&3 Promotion for Unity Connection
stcramer
I'm migrating a customer from CUCM 4.x to 8.x and from Unity Connection 4.x to 8.x. I have found the CUCM-USR-LIC top level SKU and the MIG-CUCM-USR SKU under that. What I'm having trouble finding (or understanding) is the SKU for the Unity upgrade option. Can someone please help?
Steve
13 Replies 13
skilambi
UNITYCN8-VUP-K9 for Uconn
Srini
The SKU provided in the reply (i.e. UNITYCN8-VUP-K9) does not reflect the $3 per user charge.  What is the $3/user SKU?
Sure it does, see attached screen shot
Srini
Does it apply to Unity 2.x upgarding to Unity Cnx 8.x?
Correct
Srini
Hi Srini,
I can see the 3x3 upgrade, however it doesnt have the option for VM - Basic, I need to get the 3x3 upgrade for SMBE 6K.
If i use this VM licence, the impact will be higher UCSS. compare to UCSS of VM-Basic under CMBE6K.
I believe these 2 threads will help. To use 3x3 you have to go to advanced VM
https://communities.cisco.com/message/65631
https://communities.cisco.com/message/67362
They might be talking about BE 5k but I believe the same logic applies
Srini
Hi Srini,
This is bit confusing, cause i managed to build configuration with Cisco Dynamic Configuration tools on CMBE5K using 3x3 upgrade to basic VM.
TOP-Level part: UNIFIED-CMBE5K.
also based on the ordering guide, top of page 18. we can see there is an option to upgrade to VM-Basic
http://www.cisco.com/web/partners/downloads/partner/WWChannels/technology/ipc/downloads/ordering_guide_for_cisco_unified_comms_mgr_bus_edtn_prod_famly.pdf
Hendro
So here is the new OG
http://www.cisco.com/web/partners/downloads/partner/WWChannels/technology/ipc/downloads/be6000_5000_ordering_guide.pdf
Either way if your intent is 6K then there is no concept of basic VM anymore, you get all the features within 6K. If you are talking about 5K I do see the 5K basic option. I think a while back it didn't have it but now it does
Srini
Thanks Srini, i just realised that no VM-basic option for SMBE6K
I'm aware that the 3 X 3 promotion no longer exists and we presently have the 9X3 promotion.  I'm presently in the process of doing an order for a CUCM upgrade and an upgrade from Unity 4.x to Unity Connection 8.X. For Untiy-->Unity Connection I've found the top level SKU ", but there is no sub SKU for UCSS. My understanding is that you would have to order 3 years of UCSS for any upgrade through the  9X2 promotion. Is there another specific SKU for this? Can someone share some light on this.
Much Thanx
UCSS shows up as a sub option when you select that SKU. under the 9 dollar program you will see ESW and UCSS
Srini
Just seen that after sending the post. Thanks anyway for your speedy response.
