ANI Based Routing
juan.anzola
Hi Guys,
Consider the following scenario:
I have a CUCM Cluster with the Following Extensions:
2XXX: Sales
3XXX: Engineering
I have a single H.323 or SIP PSTN GW.
I have 2 different ITSP: 10.2.2.2 and 10.3.3.3
Right now, All calls are routing properly throug 10.2.2.2
I want calls from 2XXX to be routed out 10.2.2.2 and calls from 3XXX to be routed out 10.3.3.3
The requirement is to do this without modifying anything in CUCM.
Thanks in advance,
6 Replies 6
Gajanan Pande
Juan,
Not very sure if the " match calling number " type of dial-peer config can be done for internal numbers but the easiest way to do it using CUCM, I wonder why such restriction ( as mentioned in the last line of your requirement ).
I would simply give them different PSTN access code ( e.g. 9 & 8 etc ) & route them using 2 route patterns to 2 diff gateways.
GP.
Pls rate helpful posts !!
Yogesh Singh
You may Use COR ..+ Answer Address
Use answer- address  1234567 following example is for your cube ,
(1002) Phone  ---- CUCM ---------- CUBE ===================== ITSP 1- Phone 2002)
(1003) Phone---- CUCM ---------- CUBE ===================== ITSP 2- Phone 2002)
Issue : When Ext 1002 makes outbound call, Call should go out through First
1-10 channels
and when Ext 1003 makes call, channels 1st ITSP should be used. 1002 should not
be able to use 2nd ITSP .
Following cmds needs to be issued on the Gateway :
dial-peer cor custom
name 1002
name 1003
dial-peer cor list 1002
member 1002
dial-peer cor list 1003
member 1003
dial-peer voice 2000 pots
DESC 1st ITSP
session Target Ipv4:X.X.X.X
corlist outgoing 1002
destination-pattern 2...
codec/voice/class codec
dial-peer voice 1002 voip
corlist incoming 1002
answer-address 1002--------------------------This we need to make more
specific according
to your dial-plans .
dial-peer voice 1003 voip
corlist incoming 1003
answer-address 1003--------------------------This we need to make more
specific according
dial-peer voice 2222 pots
desc 2nd ITSP
session target ipv4:x.x.x.x
corlist outgoing 1003
codec / voice class codec
Hope this helps..
Hi Yogesh,
     Thank you for your time! My first concern, was that using Incoming Dial-Peers with "answer-address" will prohibit the use of a global "incoming called-number ." in any other Dial-Peer. I will have to use a more specific "incoming called-number" por incoming PSTN Calls. I will try this in my lab and let you know.
Thanks!
Did it work ?
Hi Yogesh,
Yes, it worked fine without the need of using COR lists. his was my Testing Scenario:
  • IP Phone with 2 Extension
    • 5001 (DID: 2123945001)
    • 5010 (DID: 2123945010)
  • PSTN Test Number: 911
  • CUCM <----H323-----> GW <----SIP-----> ITSP1(10.10.101.1)
                                                    SIP -----> ITSP2(10.10.102.1)
  • Calls from 5001 should route to ITSP1
  • Calls from 5010 should route to ITSP2
SOLUTION
  • Create 3 different Incoming Dial-Peers (For this to work, the "incoming called number" should be specific to the digits delivered by the ITSP's)
    • Incoming Dial-Peer for ANI=5001
    • Incoming Dial-Peer for ANI=5010
    • Incoming Dial-Peer for DNIS=212394XXXX
  • Create 2 "voice translation profiles" for the following:
    • Prefix "#" at the incoming call leg when ANI=5010
    • Strip "#" at the outgoing call leg when DNIS=#911
CONFIG
voice translation-rule 1
rule 1 /#/ //
voice translation-rule 2
rule 1 /.*/ /#\0/
voice translation-profile STRIP#
translate called 1
voice translation-profile PREFIX#
translate called 2
dial-peer voice 100 voip
description CALLS-TO-CUCM
destination-pattern 2123945...
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.210.11
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 101 voip
preference 1
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.210.10
no vad
dial-peer voice 911 voip
description OUTGOING-LEG-ITSP1
destination-pattern 911
session protocol sipv2
session target ipv4:10.10.101.1
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 9911 voip
description OUTGOING-LEG-ITSP2
translation-profile outgoing STRIP#
destination-pattern #911
session target ipv4:10.10.102.1
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 95001 voip
description INCOMING-LEG-ITSP1
answer-address 5001
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 95010 voip
description INCOMING-LEG-ITSP2
translation-profile incoming PREFIX#
answer-address 5010
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 999 voip
description INCOMING-LEG-FROM-PSTN
incoming called-number 2123945...
codec g711ulaw
Great ! Nice alternative  :-)
Yogesh
