07-09-2017 09:48 AM - edited 03-19-2019 12:36 PM
I'm searching for a procedure to change the MD5 password on the 3845 that securely communicates with the SyncServer S350 NTP. Your input is appreciated...Mike
07-09-2017 11:17 AM
Hi Mike,
On the 3825 can you provide output of the following command
show run | sec ntp
07-10-2017 07:10 AM
Grant,
Cannot provide output due to special circumstances. Is it possible there is a best practices document or procedure for configuring the 3845/NTP using MD5 hash. As I understand, the sequence is important when changing passwords on both devices because this can lead to locking out or disabling the equipment.
Mike
07-10-2017 07:33 AM
Not familiar withe the SyncServer S350 but for NTP config on IOS Devices see below
(A lot easier reading that some of the Cisco Official documentation)
Paul Stewarts blog, who is a CSC regular.
http://www.packetu.com/2008/12/28/ntp-authentication-ciscos-implementation/
and.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/bsm/command/bsm-cr-book/bsm-cr-n1.html#wp2286071162
There is really not much to it on the Cisco end. Just have to ensure the SyncServer matches up I would assume.
I have never heard of being locked out a Cisco device if the NTP for it was out of sync. If your whole AD environments time was drfiting then there may be a ripple down if using TACACs / ACS integrated with AD or similar.
Maybe someone else can advise otherwise though.
