09-20-2016 12:23 AM - edited 03-19-2019 11:36 AM
how to apply newly added or edited route pattern to Cisco Unified CM Administration
09-20-2016 12:28 AM
Map the route pattern to Route List/Trunk/Device.
Refer below link
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/6361-dp-isdn-gateway.html#Topic2
09-20-2016 01:07 AM
09-20-2016 01:13 AM
Can you grab DNA report
09-20-2016 09:10 AM
You don't have to do anything when you change anything in your dial plan, CUCM will start using the new info right after you hit save.
You need to troubleshoot this as any other dial plan issue, start by looking at the config, CSS, partitions, etc.
