cucm 10.5 moh works intermittently
ciscoceci
Hi everyone,
I have the follow issue, sometimes when some extension in my environment put a call on hold the moh doesn´t works, after a 1 or 2 seconds works again.
the source is a .wav
some one any idea?
thanks Anna.
5 Replies 5
Jaime Valencia
Is this unicast? multicast?
Does the default MOH works?
What troubleshooting have you done??
java
if this helps, please rate
Thanks Jaime,
it is unicast, we don´t test if default works. We have get the logs in RTMT from media service and tufts but didn´t see nothing
thanks Anna
You said the MOH works intermittently. For this you need to isolate which type of calls are affected, internal or external or both? Is it affecting phones in a specific location, device pool or all of them randomly? Have you ensured that the MOH file is uploaded on all servers if you are not using the default MOH file? Do some further probing before getting into RTMT or traces.
Manish
thanks!!,
Today the MOH doesn´t work for no ip phone, we have tested that when any ip pone put call in hold (all of them) we only hear a distorsioned sound but no music.
Thanks Anna
Can you check and reply to the following specific question:
What happens if you try to place a call on hold between two IP phones registered on same cucm server with default MOH audio source assigned to the IP phones?
Manish
