CUCM Certs for Jabber
mbowden7
So here's my problem. I have Cisco Jabber on MAC/PC 11.7.0 getting it's .xml from CUCM 10.5.2, but I have a Linux server that holds my Cisco Jabber software upgrades and whenever an end user gets the prompt to upgrade they get a cert error of that Linux server. I have installed a CA cert on the Linux server, but does it have to be installed on CUCM or IM&P. It only does this on MAC
Aseem Anand
Do you have the CA's root certificate uploaded in the certificate repository of the MAC workstation?
Aseem
no, but the problem would be for all MAC workstation. So in return, I would have to upload the CA Cert to all of them?
That is how certificates work, they need to trusted by the devices. If this was a known CA most of their root certs are pre-installed on operating systems such as Windows or Mac OX, but if you signed the cert with your CA or the CA's root is not one of the pre-loaded ones then you need to push the certs to the clients.
