CUE question
fadyawad1
Hi All,
Can i make my CUE to be dialled from external numbers, for example if i am out of the office and need to check my voicemail can i dial a certain number to be connected to my voicemail. Do i need to create a dial-peer.
Currently that's the config of the VM dial-peer
dial-peer voice 8000 voip
description CUE VM
destination-pattern 8000
session protocol sipv2
session target ipv4:
dtmf-relay sip-notify
codec g711ulaw
no vad
Thanks.
Ajay Singh
Hi Fady,
Ues this is very much possible. User needs to dial a specific PSTN number from outside , authenticate and access.
There is an older post on this forum about the same and it can help you understand:
https://supportforums.cisco.com/thread/309934
Cheers,
Ajay
Please rate if helps
Hi Ajay,
thanks for your prompt feedback and the useful link.
they are speaking about 2 options;
1- get in from the AA, which i don't have it working on my system
2- dial in a specific number from outside, this one should be configured somewhere.
my questions (sorry, still a question) is where do i configure this number (on the CUE, CME .. etc,) and i believe i should create a dial-peer for this one, do I?
Thanks a lot
Cheers, Fady
Hi Fady,
You need specific dial peers on CME to connect to Voicemail pilot. THe number which will be dialled from outside (with DN Range) should be able to talk to CUE.
IF you closely read the thread that i have refered here, it is also mentioned into it.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unity-express/62609-tdcmecue.html#t12
Hope this helps.
Ajay Singh
Please rate if useful.
