CUPS 10.5 INSTALLATION ERROR
When i try to install cups 10.5.2 (10.5.2.20000-1 unrestricted ) in the final part i get a error message that saids is a critical error:
"The Installation has encountered a unrecoverable internal error. For further assistance report the following information to your support provider.
"/usr/local/cm/script/cm-db1-install
install
PostInstall 10.0.1.1000-26 10.0.1.1000-26
/usr/local/cm
/usr/local/cm/
/common/log/install/capture.txt" failed (1)
The system will halt now.
Continuing will allow you......diagnostic information before halting."
I dont know what is my problem if its a bug or something....
Can you please help me???
Terry Cheema
Hi Bruno - Just to confirm - do you know you are trying to install un-restricted version? Whats your hardware - has it got sufficient resources to full support the IM&P.
Secondly have you added the presence node in CUCM - IM&P are same as CUCM Sub servers and needs to be added on CUCM pub before installation? If yes, try deleting and re-adding and then try install if it makes a difference.
You can also scroll through installation logs for any error etc.
Also read through the Pr-requisites here:
Ref: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/install/10_0_1/CUCM_BK_I95AD2FE_00_installing-cucm-100/CUCM_BK_I95AD2FE_00_installing-cucm-100_chapter_011.html#CUP0_TK_P8901E0C_00
-Terry
Please rate all helpful posts
Jaime Valencia
If you're supposedly installing 10.5(2) why is the error you're posting saying 10.0(1)????
java
if this helps, please rate
