Encypted CUCM Upgrade - HELP!!!
lukas1982
Hi all,
i'v a question about the upgrade process for a CUCM Cluster.
I Deployed a CUCM 7.1(5) with Encyption (Mixed Mode) and all works fine.
Now i need to upgrade the cluster, with an hardware replace, t the last CUCM 9.1(1a) relase.
I rebuild the entire cluster in my lab with the CUCM version 7.1(5), than I Import a valid Backup and i'll upgrade the cluster (To UCS Server) to 9.1.
What does i'vto do for the Encyption?
Should be work without any change or i need to reconfigure IT?
Plese Help Me!!
BR,
Luca.
Hi Luca,
How did it work?
Cornel
Hi Cornel,
whene the Import of the new Backup was fine I reissue all the cerficiate (in CUCM 9.X)  with the CTL Client using the same USB token used before the upgrade (in version 7.X).
Luca.
