Head set for Cisco 8961 IP Phone with expansion module??
ANUJ BUTAIL
Can someone please recommend headset for Cisco8961 which has expansion module to be used as receptionist console??
Anuj
srichardson
Level 4
Level 4
I totally love my old Jabra 9350 wireless headset. I work from home and can walk 4 houses away and still communicate.
Here are the newer models to look at:
Jabra GN9350e
Jabra PRO 9450 Flex
Jabra PRO 9460 Mono
Jabra PRO 9470
http://www.jabra.com/headsets-and-speakerphones/compatibilityguide
Stephanie,
Does the Jabra PRO 9470  headset will provide the option of remote call pickup and hang-up or is there additional equipment/adaptors needed to do this?
Jabra PRO 9470 can do remote call control functionality with 8961 series phone. Jabra has developed USB cable specially for Cisco 8961 and 9900 series USB phones
http://jabra.com/Products/Wireless_Headsets/Jabra_PRO__9400_Series/Jabra_PRO_9470
Since Jabra PRO 9470 is DECT base, it has good range of 450 ft. That means you can do call control which includes answer / end call, change volume, mute/unmute with in 450 ft
Triple Connectivity - Unique Touch Screen Headset, which can connect with Cisco Softclient (via USB), Cisco Phone (via RJ9) and Your mobile device or iPad (via Blue Tooth)
All Three connections are active at any time, that means - you can receive call on any device but you can anser with just one headset
