03-26-2020 06:19 AM
i have built a System Call handler for one site, i setup caller in puts and Uploaded greeting and it working fine
+++but customer Wanted calls to be transfer to an external number and it should be activate manually
for this i created another handler in the name of "closed hours" and enabled transfer to External number , if the alternate or closed greeting enabled calls will flow to external number via "closed hours" call handler.
now the problem is how to toggle between the greetings of a call handler for activating and deactivating them
++ I can not use scheduler as the customer wants to do it Manually
any Ideas ...?
Krishna
Solved! Go to Solution.
03-26-2020 08:13 AM
03-26-2020 07:45 AM
Use the greetings administrtor to toggle between the standard and alternate greetings as required
03-26-2020 07:58 AM - edited 03-26-2020 08:00 AM
HI Java,
I Configured the same as below, but customer is saying its long procedure, asking for some short procedure to do it.
For IVR:
1)From landline phone dial 800012
2) Enter Greeting admin id 50003
3) PIN:XXXXX
4) Enter call handler number 161XXXXXX01
5) Enable alternate greeting on Night Shifts and Holidays,
6) Switch to Standard Greeting on Normal Working hours
krishna
03-26-2020 08:13 AM
Their other option is CUC admin.
