Incorporate US and GBNP dialing plans
wplantier
I have my CUCM up and running and US and US to international calls are working great. After I got my CUCM 7 up and running and all the dial plans working they have decided to add our London office to the mix. I current have a 9[2-9]XXXXXXX for local calls. I have added 9.@ for my London users but it prefers the US local call routes. What is the best way to fix this?
Thanks.
7 Replies 7
asandborgh
Level 4
Level 4
Spencer,
I don't use 9.@ - like to put mine together from scratch,
Having done a bit of this for clients around the globe I have found that the easiest place to find 95% of the information to build a dial plan for a country is on Wikipedia:
http://en.wikipedia.org/wiki/Telephone_numbers_in_England
The following is from a gig a couple years ago - some country dial plans change on a regular basis so this might not be accurate today
112
Emer calls
999
Emer calls
0.112
Emer calls
0.999
Emer calls
0.00!
International dialing
0.00!#
International dialing with dial string terminating character
0.020XXXXXXXX
Local 11-digit dialing
0.0[1-8]XXXXXXXXX
11 digit dialing
0.07[5789]XXXXXXXX
Mobile – are mobile’s considered LD?
0.0900!
Blocks calls to 1-900 numbers
0.084!
0.087!
0.0800!
Toll Free numbers
Cheers!
Art
asandborgh
Level 4
Level 4
Oh - one thing about the chart I sent.  Normally from what I understand they dial 9
to get an outside trunk in England (I'm a yank), but this client wanted to use 0 for the trunk access code.  FYI
ooh - one more thing - this was an office in Hemel Hemstead, just NW of London so I'm not sure what would be a "local call" from you location
Additionally I always check out the dail plan with a local resource so they can add or correct before it goes into production.
I think thats it for now......
Paul Reck
Hi Spencer,
In addition to Art's good advice (+5) you also have the option of downloading and installing the GB Number plan
http://tinyurl.com/yhy65r3 (link to CCO downloads)
and you can then use the 9@ route pattern by selecting GBNP from the Numbering Plan drop down box, and use route filters to Class of Restriction in the same way you might use them for the US dial plan.
Paul
Normally from what I understand they dial 9 to get an outside trunk in England (I'm a yank), but this client wanted to use 0 for the trunk access code.
The 0 is used as the national trunk code for long distance calling. This will be followed by an area code and number.
In many offices, 9 is used to get a line out of the building you're in. This will be followed by a local number or by a 0 and then the long distance area code and number as above.
Hi Spencer
Typically your London phones should never reach the local, US 9[2-9]XXXXXXX pattern - if someone from the UK wants to dial the US they will dial  001whatever as it's international. The US 9[2-9]XXXXXXX should be in a partition that is not in the UK-phone CSS.
This will apply regardless of whether you use the UK dial plan/@ (which I would recommend and use all the time, as I'm UK based) or if you define the patterns manually.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
0.0[1-8]XXXXXXXXX           11 digit dialing
That pattern ignores the fact that 41 UK area codes have some numbers which are a digit shorter.
Additionally, all 0500 and some 0800 numbers are one digit shorter than usual.
0.07[5789]XXXXXXXX        Mobile
Mobile numbers also begin with 074XX these days.
Additionally, the 07624 range is used by mobile phones in the Isle of Man.
