Lync 2013 and Cisco Presence
Jeff Martin
I have not been able to find a clear answer online so I figured I would ask here. Is it possible to integrate a Lync 2013 server with Cisco Presence Server (8.5) and recieve status updates in the Lync Client. For example, when I pick up my phone will it change my status to busy or "on a call"? I know that the Cisco Jabber client will do this as I deployed it in another environment.
Chris Deren
It is possible with Lync 2010, I dont think Lync 2013 is officially supported yet, though it should be any day.
Chris
Jason Newman
Jeff,
Chris is correct.  This is not yet offically supported.  Though I have seen many cases in which it works fine because the underlying communication for Remote Call Control has not changed between the two versions.   I have seen a handful of customers where this worked just fine with 2013.
Jason
