Masking the incoming calls (from Mobile phone) to CUCM 10.5
Eng Yeong Ng
Hi Experts,
Good Day, may i know possible to configure the CUCM's masking for the incoming calls (i.e : mobile calls) to my desk phone and the incoming number display as PRIVATE ?
Thanks a lot.
Adarsh Chauhan
Level 3
Level 3
if you can make the incoming call route through a Translation pattern then you may use the following settings in the TP to make the calling ID PRIVATE.
Please rate and mark if helpful
Adarsh Chauhan
Please rate and mark correct if helpful
Adarsh Chauhan
