Message Store Manager utility for Unity Connection 8.5?
Jason Aarons
Level 6
Level 6
Is there a tool I can peep into subscriber mailboxes/delete messages like Message Store Monitor but for Unity Connection 8.5 ?
I need to look at Unity/Unity Connection reporting in web/sa and cuadmin showing subscriber how many messages, mailbox size, last accessed for both Unity 4.2 and UCXN 8.5.
5 Replies 5
Rob Huffman
Hi Jason,
To find out the info for Number of Messages etc. you can use the Connection
User data Dump from the great Unity Tools
http://www.ciscounitytools.com/Applications/CxN/UserDataDump/UserDataDump.html
and then to delete messages;
From Master Lindborg
"For Unity Connection (where we store messaged in our own database) you can use the Bulk USer Delete tool
(which includes a mailbox reset function that lets you optionally remove all messages for selected users if you like)"
http://www.ciscounitytools.com/Applications/CxN/BulkUserDelete/BulkUserDelete.html
Cheers!
Rob
Can you tell me where to find the tool that Jason was asking about if I have a Unity 7.x server?
Rob Huffman
Thanks Rob. One other question. I see that Unity 7.x is supported. Is it supported if I'm integrated with Exchange 2010?
Rob Huffman
Hi Brian,
I don't believe the MSM Tool is supported here I haven't seen any updates since Scott
posted this good note;
https://supportforums.cisco.com/message/3273842#3273842
Cheers!
Rob
