04-23-2015 12:59 PM
hi fellow ciscoers. I wanted to see if there is a way for CUCM enterprise edition that can do some type of paging to a security desk or maintenance desk from the secretary desk. Example: secretary sits in a lobby with a phone and if there is an emergency she or he could call the security/guard with just a push of button on the phone or something that is near her that would ring the security/guard.
04-23-2015 01:49 PM
Since CUCM 9x the 'InformaCast' basic paging app is included with CUCM, with this you can accomplish this.
HTH.
Christian.
04-23-2015 01:54 PM
You can use apps like Singlewire or Syn apps.
04-24-2015 05:23 AM
Thanks for the response the company CUCM is on 8.6 right now. I have to asked if they are going to upgrade or not. I will respond if when I get an answer on it.
