please help ..Can I modify the jabberwerx.ui.RosterView to different layout or color or add pic ??
ZengYang-zy5
Can I modify the jabberwerx.ui.RosterView to different layout or color or add pic ?? or do you have jabberwerx.ui.RosterView in another design and layout .
Jaime Valencia
If this is in reference to SDK, you probably want to try in DevNet, if not, anything that is not documented, is considered un-supported and you won't find info on it.
java
if this helps, please rate
