06-01-2017 07:08 AM - edited 03-19-2019 12:29 PM
Hello All,
I'am trying to figure out a comparison between Skype for Business and Jabber with Expressway. How does Skype for Business work when you are outside of the organization similar to how Jabber would work with expressway? Is there any good documentation on a comparison. I know that CUCM can integrate with Skype for Business server through a SIP trunk. Thanks
Jason
Solved! Go to Solution.
06-01-2017 04:27 PM
MS has pretty much same concept of Expressway-C and Edge. You need a Microsoft edge server to achieve this.
https://technet.microsoft.com/en-us/library/dn933903.aspx
Alok
06-01-2017 08:08 AM
Obviously not a MS guy, but from what I know they use DAS as the equivalent of MRA
https://support.microsoft.com/en-us/help/3193843/lync-2013-skype-for-business-connects-through-the-directaccess-tunnel-when-you-connect-to-an-external-network
06-01-2017 04:27 PM
Alok
