SNMP OIDs for various dial-peer configuration items
Adan Zuniga
I am looking for a MIBs that can report on various dial-peer configuration items on CUBE's. Following this document, I
found the following OIDS:
DIAL-CONTROL-MIB::dialCtlPeerCfgOriginateAddress
CISCO-VOICE-DIAL-CONTROL-MIB::cvVoIPPeerCfgSessionTarget
 that cointain the destination pattern & session target of a dial-peer respectively. However, these OIDs do not report e164-pattern-maps as destination patterns nor server groups as session targets. Are there any OID's that will report e164-pattern-maps and  server groups as well as the configurations for these items?
Imran Ul Haq
Hi There
Did you get anywhere with this?
I am trying to create an xml template for Zabbix to capture inbound and outbound call volumes over a sip trunk, and i dont think the template already exists.
Wondering if your solution can help shed light on mine.
regards
imran
