Unified CM Lines Without Phones
campfreddie100
Unified CM Lines Without Phones in Ver: 10.5.2.12901-1 Unrestricted
Hello Guys, I have phone lines not currently associated with physical phones. If I wanted to convert these lines to DID's can I just add refurbished phone equipment from a CISCO reseller and assign them. These lines should be included in my licensing correct?  Thanks
TONY SMITH
When you say "phone lines not currently associated with physical phones" do you mean Unassigned DNs?
If so then these won't be consuming licences.  To confirm this look at "System/Licensing/License Usage Report" on CUCM (not PLM).  From there you can see itemised lists of exactly what is consuming licences at the moment.
