06-25-2018 01:17 AM - edited 03-19-2019 01:26 PM
Hi if I try to activate the media app in greetings to play, download and upload records it gives me a java error.
I try to use Audiotext Manager from http://www.ciscounitytools.com following the instructions here. http://www.ciscounitytools.com/Applications/CxN/ATM/Help/ConnectionAudiotextManager.htm including install IBM Sdk.
But when I try to login try to login on the server I have this error.
Connection to Remote Server Failed: ERROR [HY000] [Informix ODBC Driver] [Informix][Informix ODBC Driver][Informix]System error occurred in network function.
I'm using windows 10
Is there another way to manage the records in Unity 11?
07-01-2018 01:06 AM
look into the ODBC 32-bit/64-bit ( https://supportforums.cisco.com/t5/unified-communications/odbc-connection-to-informix-will-not-connect/td-p/2571407 )
Anyhow Why Java is failing is another thing, Java fails mainly because it treats the website as not trusted website , Try the following
1) Add the Unity Tomcat Certificate to the Trusted Root certificate on your windows
2) Add the Unity website on the Trusted websites on Java Configuration - ControlPanel
3) Decrease the Security or add the site as trusted website on your IE
07-01-2018 11:46 PM
Thank you for the answer.
Finally I could make it work using windows 7 machine.
Best Regards
07-03-2018 05:41 AM
