Upgrade Loop CP-8945 SIP 9-4-2SR2-2
Kevin ngandu
I have a problem with four CP-8945 which does not seem to support the SIP protocol, they do a bug with updgrade loop though the other phones of same type sound operational with the SIP version 9-4-2SR2-2 and even If I try to insert it via a CME but the same version bug, an help on your part will do me a great good
keglass
Level 7
Level 7
Kevin,
I recommend you also post this to the Cisco Support Community for additional feedback and information.
https://supportforums.cisco.com/
I hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
