fail to upgrade infra firmware on UCSM
brlok
Hi folks,
I have successfully uploaded a new infra bundle firmware 2.2.(8a) to UCSM, but it was failed to list the downloaded firmware in Auto-Install when attempting to install Infra firmware.  It only show the existing firmware version in the dropdown box
I then tried to upgrade it through command line directly, it is still same.  here is the output:
has anyone encountered the same issue, and how did you fix it please?
I also rebooted both FI, but no luck.
the same infra image file which I used, was successfully upgraded on other pair of FI
Product Name: Cisco UCS 6248UP
Running firmware: 2.2(3c)
UCS-B /firmware # show download-task
Download task:
File Name Protocol Server Userid State
ucs-k9-bundle-b-series.2.2.5a.B.bin
Local local Downloaded
ucs-k9-bundle-c-series.2.2.5a.C.bin
ucs-k9-bundle-infra.2.2.5a.A.bin
ucs-k9-bundle-infra.2.2.8a.A.bin
UCS-B /firmware #
UCS-B /firmware #
UCS-B /firmware # scope auto-install
UCS-B /firmware/auto-install # install infra infra-vers 2.2(8a)
This operation upgrades firmware on UCS Infrastructure Components
(UCS manager, Fabric Interconnects and IOMs).
Here is the checklist of things that are recommended before starting Auto-Install
(1) Review current critical/major faults
(2) Initiate a configuration backup
(3) Check if Management Interface Monitoring Policy is enabled
(4) Check if there is a pending Fabric Interconnect Reboot activitiy
(5) Ensure NTP is configured
Do you want to proceed? (yes/no):yes
Triggering Install-Infra with:
Infrastructure Pack Version: 2.2(8a)
Software Error: Exception during execution: [Firmware Package with version 2.2(8a) is not available]
UCS-B /firmware/auto-install # install infra infra-vers 2.2.8a
Infrastructure Pack Version: 2.2.8a
Software Error: Exception during execution: [Firmware Package with version 2.2.8a is not available]
10 Replies 10
Walter Dey
do you have enough space ?
did the download Task run successfully ?
list the packages in UCSM ? can you see it there ?
do you have enough space ? yes, deleted all unnecessary packages
did the download Task run successfully ? yes it shows download successfully, no error seen
list the packages in UCSM ? can you see it there ? yes i can see.
> only issue is that the target image is not available/showed in the dropdown box when trying to proceed infra upgrade in Auto-install
Do you use ntp server ? are the 2 FI's time wise in synch ?
Do you use the "Force" option ?
I would delete the 2.2.8 infra bundle, and then try one more time,  or try 2.2.7 to see if it is version dependent.
I deleted all of them, only 2.2.5a.A is in Downloaded Tasks, and I saw it Packages
It is not about force action, it is NOT available to choose the target version in "Auto-Install "and also in "Activate Firmware"
Did you try to download another version e.g. 2.2.7 and check, if the behaviour is the same ?
i tried, but no different...
Is this a productive environment or lab ?
2.2.3 is really a weird release !
If lab ? why not backup, then erase configuration and restore ?
it is fixed by cleaning up all existing packages
Mohammed Majid Hussain
Can you please paste the output of "show system internal flash" from both the FI's ?
# connect nxos a
(nxos)# show system internal flash
(nxos)#  exit
# connect nxos b
UCS-B# connect nxos a
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2014, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
UCS-A(nxos)# show system internal flash
Mount-on 1K-blocks Used Available Use% Filesystem
/ 307200 180596 126604 59 /dev/root
/proc 0 0 0 0 proc
/post 2048 4 2044 1 none
/var 307200 180596 126604 59 none
/sys 0 0 0 0 none
/isan 3072000 1031652 2040348 34 none
/var/tmp 614400 980 613420 1 none
/var/sysmgr 2048000 18148 2029852 1 none
/var/sysmgr/ftp 143360 72 143288 1 none
/callhome 131072 0 131072 0 none
/dev/shm 524288 286036 238252 55 none
/volatile 245760 4 245756 1 none
/debug 8192 0 8192 0 none
/dev/mqueue 0 0 0 0 none
/debugfs 0 0 0 0 nodev
/mnt/plog 49024 1324 47700 3 /dev/mtdblock2
/mnt/cfg/0 85528 4156 76956 6 /dev/sda5
/mnt/cfg/1 85528 4156 76956 6 /dev/sda6
/var/sysmgr/startup-cfg 409600 44 409556 1 none
/dev/pts 0 0 0 0 devpts
/mnt/pss 85549 6365 74767 8 /dev/sda4
/bootflash 16721844 5527616 10344792 35 /dev/sda3
/opt 3970300 105260 3664632 3 /dev/sda7
/opt/db/nvram 3963 2095 1664 56 /dev/mtdblock3
/workspace 3945128 36848 3707872 1 /dev/sda8
/spare 5882244 32836 5550604 1 /dev/sda9
/bootflash/sysdebug/tftpd_logs 1024 8 1016 1 tmpfs
UCS-A(nxos)#
UCS-A(nxos)# exit
UCS-B# connect nxos b
UCS-B(nxos)# show system internal flash
/ 307200 180556 126644 59 /dev/root
/proc 0 0 0 0 proc
/var 307200 180556 126644 59 none
/sys 0 0 0 0 none
/isan 3072000 1031780 2040220 34 none
/var/tmp 614400 988 613412 1 none
/var/sysmgr 2048000 28232 2019768 2 none
/dev/shm 524288 286148 238140 55 none
/mnt/plog 49024 1348 47676 3 /dev/mtdblock2
/mnt/pss 85549 6308 74824 8 /dev/sda4
/bootflash 16721844 5529732 10342676 35 /dev/sda3
/opt 3970300 162932 3606960 5 /dev/sda7
/opt/db/nvram 3963 2096 1663 56 /dev/mtdblock3
/bootflash/sysdebug/tftpd_logs 1024 16 1008 2 tmpfs
UCS-B(nxos)#
