how to connect c240 to FI in direct mode
licheng19891220
I have upgrade fi to 2.2(1b) and the cna adapter to the newest version,
The 1225 adapter is in pci 2 slot.
then i connect 240 rack server to fi ,and the fi port is server port.
but i can not discovry 240 , and i don't konw why
any idea ? thanks
smcquerr
Level 4
Level 4
Cheng,
The most common issue with Discovery is when a rack server server was used for something prior to integration or has some setup on the CIMC.  Try connnecting a Keyboard and Mouse to the system and Press F8 to enter the CIMC configuration.  Then set the CIMC to factory defaults.  After you do this connect to the FI again and try discovery.
Steve McQuerry
UCS - Technical Marketing
smcquerr
Level 4
Level 4
Cheng,
Steve McQuerry
Thanks for you support
