10-02-2019 07:30 AM
we are inserting M5 blade into chassis it gets stuck at the Discovery stage. The new blade comes with new 4.0(4a) firmware, only way to fix this is manually downgrading the FW to 3.2(3x). Is there any way we can downgrade the firmware automatically once the new blade is inserted into the chassis?
10-02-2019 07:35 AM
UCSM needs to be 4.0 minimum to support M5 servers.
10-02-2019 07:48 AM
the support for B200 M5 blade was started from 3.2(1d) version.
10-02-2019 07:57 AM
Okay, I figured you had the new processors since this was a new blade. Did not have all the info on your build.
You can use auto-install to downgrade the blades automatically once you install them in UCSM.
10-07-2019 09:39 AM
