VSAN Configuration between UCS FI and Nexus 5K
Kshitij Purwar
Hi Experts,
Please help me to understand VSAN deployment between FI and Nexus 5K over Traditional FC.
Should i use 2 different VSAN between FI and N5K or one VSAN on both side would be fine.
if there is any reference doc please send me link.
i would appreciate your responses.
k
11 Replies 11
Walter Dey
I assume you have 2 N5k ?
In any case, one would create a dual fabric: FI-A and N5k-A resp. FI-B and N5k-B;
In each fabric you create at least one VSAN, which should be different in fabric A and B.
Zoning is done per fabric and vsan
https://supportforums.cisco.com/discussion/11912046/configure-nexus-5548-native-fc
Thanks Walter For your Reply. I read all the docs ,but it is not mention anywhere what is the benefit of using 2 vsan with infrastructure. I have 2 N5K and 2 FI and 3 Storage. i would appreciate if you could please help me to identify of advantage using 2 vsan in infrastructure.
Hi Kshitij
Sorry for not being clear.
In the FC world, we talk about 2 separate / isolated fabrics.
This means: you create a VSAN eg. 10 on FI-A and N5k-A ; and another VSAN eg. 20 on FI-B and N5k-B.
Your server (service profile) has 2 vhba's, one in Fabric A (VSAN 10) the other one in Fabric B (VSAN 20).
Your storage is also dual homed to Fabric A (VSAN 10) resp. Fabric B (VSAN 20).
Zoning is done per VSAN !
Thanks a Lot for wonderful Explanation,but my query is why i need 2 VSAN if everything can work well if i use only 1 vsan within infrastructure.
is this a best practice to use 2 vsan or there are some benefits to use 2 vsan like fail over,load-balancing.
what i can not achieve if i use only 1 vsan.
This FC dual fabric is best practise / recommendation since 20+ years; it's done by IBM, EMC, HP, NetApp,....
see eg. slide 28 or 55 in
http://www.alcatron.net/Cisco%20Live%202013%20Melbourne/Cisco%20Live%20Content/Data%20Centre%20And%20Virtualisation/BRKCOM-2002%20%20UCS%20Supported%20Storage%20Architectures%20and%20Best%20Practices%20with%20Storage.pdf
If you have eg only one vsan, and someone plugs a cable between a FC port connecting the 2 N5k, you merge the 2 separate fabrics, which could end in a disaster.
If however, the ports are in 2 different VSAN's, fabric merge will not happen.
And please don't use VSAN id = 1 ; it's Special, cannot be deleted; all interfaces are basically in VSAN 1.
Thanks a Lot walter for your Time and sharing this doc.
Really a good technical presentation.
After reading this doc,now its clear -
1. I should use 2 vsan
2. i should also use san port-channel.
but i have 2 query-
1. should i use manually pin group on FI FC uplinks.
2. should i enable full zonset distribution when we have 2 different vsan on fabric.
kshitij
Yes, minimum is one vsan per fabric ! you could have more, e.g. for separating Windows and Linux servers
yes ! your FI should be configured as FC end host (default setting). and then on your N5k, you have to enable
cae-sj9506(config)# feature fport-channel-trunk
see eg. https://supportforums.cisco.com/sites/default/files/legacy/9/9/2/53299-UCS_1-4-1_F-port_channel-trunk-v1.pdf
No, this is usually not done. automating pinning is the default !
I assume, your FC fabric consists only of one switch (N5k), therefore it doesn't matter !
Please be aware, that there is FC NO link between the 2 N5k's
Thanks a Lot walter.
After reading your pointers and google search,i found out some learning,below is the summary -
1. i should use 2 vsan as best practice.
2. I should use device alias for zoning-
Query- As per the nexus doc we can create device alias in 2 manner,first as direct memeber of zone second create a device alias under fc-alias and add fc alias as member of zone.
Please suggest which one is good.
3. I should use F-port channel between UCS and nexus 5K
- As per the doc i should use seperate vsan on each FI and N5k and active mode on F-port channel.
on FI A side and nexus A side,i will enable vsan 100 on F port channel and on FI B side and nexus B side,i will enable vsan 200 on F port channel.
but reffering to below link,person has created 2 vsan on each Nexus and manually enabling  vsan on each uplink.
https://virtuallymikebrown.com/2013/05/23/cisco-nexus-fibre-channel-configuration-template/
it is still confusing,how will it work.
please suggest.should i follow him.
yes ! there is also a fc-alias which works differently ! see e.g.
http://blog.scottlowe.org/2010/12/08/using-device-aliases-on-a-cisco-mds/
http://etctc.net/cisco/san/2015/08/26/Cisco-fcalias-or-device-alias/
http://lejyphilip.blogspot.ch/2012/08/dfference-between-fcalias-device-alias.html
https://supportforums.cisco.com/discussion/10425736/what-difference-between-fcalias-device-alias
yes !
yes ! correct !
The reference https://virtuallymikebrown.com/2013/05/23/cisco-nexus-fibre-channel-conf... is totally misleading resp. wrong !
It shows a ISL link between the 2 MDS, trunking the 2 VSAN's of fabric A resp B. This would merge the 2 fabrics into one !
If you read the text carefully
.......So in short, this ISL is not needed. I’ll be removing it the next chance I get.......
Thanks Walter.
what is the use case of ISL.where should i use it.
As i know this is also use in ethernet to configure a trunk port to pass different vlans,but how it is related in san switch,where we can active only one vsan per switch.
confused.....
Hi Kshitij
In case of N5k
no FC ISL between switches ! this is the guarantee for a dual fabric !
yes Ethernet ISL/trunk between switches , vPC is the recommendation here !
Walter.
