12-10-2004 09:17 AM
I have got major voice quality problems through a 2600 gateway using a VIC2B-S/T.
I have tried :-
New IOS
New NM-1V
New VIC2B-S/T
Different router chassis - 2621 & 2611XM
Different ISDN circuits
Different ISDN cable
Adding the gateway to my own CCM cluster (as opposed to customer's CCM cluster).
So, I've tried pretty much everything but still get really bad voice quality - even ringback is bad.
This isn't even a problem with QoS on the LAN since the gateway is now on our live CCM network where we have a 2600 E1 MGCP g/w and this works fine (and has done for 3 years).
Here's the relevent config :-
isdn switch-type basic-net3
call rsvp-sync
interface FastEthernet0/0
ip address 192.168.40.3 255.255.255.0
duplex auto
speed auto
interface BRI1/0
no ip address
isdn incoming-voice voice
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.40.1
ip http server
voice-port 1/0/0
dial-peer cor custom
dial-peer voice 9 pots
incoming called-number .
destination-pattern 9T
direct-inward-dial
port 1/0/0
dial-peer voice 760471 voip
answer-address 760471
destination-pattern 760471
session target ipv4:192.168.30.3
Any help or pointers would be very much appreciated. I really can't think of what else to try.
Thanks in advance,
Paul.
12-17-2004 08:16 AM
Hi Paul,
You could check the trouble shooting section under : www.cisco.com/techsupport/---------> Products ----------> Routers ---------> 2600 Series
12-21-2004 08:30 PM
add the command 'compand-type a-law' under the voice port 1/0/0
The default coding on the BRI cards is ulaw, so the audio coming in will be all distorted if there is a codng mismatch.
Be aware that if you use a BRI VIC in a NM-1V, you will onl be able to get one port to fuction as there is only 2 DSP resources on the NM-1V card and the BRI VIC can handle 2 BRI ports, or 4 calls.
12-22-2004 04:30 AM
Thanks for that Paul - it works !!
