Application Error
chuck.huffman
After unistalling Microsoft Essentials cisco uc fails to run. Reinstalling cisco uc made no difference same error.
Faulting application name: cucimoc.exe, version: 8.5.217.19836, time stamp: 0x4eefe3fe
Faulting module name: KERNELBASE.dll, version: 6.1.7601.18229, time stamp: 0x51fb10c6
Exception code: 0xe053534f
Fault offset: 0x0000812f
Faulting process id: 0x%9
Faulting application start time: 0x%10
Faulting application path: %11
Faulting module path: %12
Report id: %13
Patrick Born
Hi Charles,
Just to be sure, are you using CUCC, right? [Cisco Unified Configurator for Collaboration]
You write about "cisco uc" but have posted in the BE6000 > CUCC section.
Anyway, it looks like Microsoft Essentials is a security package/solution and it appears that when it was uninstalled, it damaged or removed some critical paths that applications rely on:
"Faulting application path: %11 Faulting module path: %12"
You say that "Reinstalling cisco uc made no difference same error." Assuming you're writing about CUCC, keep in mind that CUCC does not really install, it is only unzipped into a directory and then you run cucc.exe.
Make sure that you really unzip/uncompress all CUCC files and don't simply use Windows Explorer to view the contents of the compressed file and then try run cucc.exe from within the compressed file.
I hate to suggest it, but you'd probably be better off starting from a known system state with a fresh install of Windows.
Best of luck,
Patrick---
