01-15-2024 02:44 AM
Hi all,
I have created a VPN and seeing strange results. The side I manage shows to sessions connected to the same endpoint with phase 1 up on one session and down on the other. BGP is enabled across the VPN but is also not coming up.
Sessions are shown below.
Interface: Tunnel100003
Profile: if-ipsec3-ikev2-profile
Session status: UP-ACTIVE
Peer: 3.11.178.77 port 4500
Session ID: 11694
IKEv2 SA: local 10.157.71.129/4500 remote 3.11.178.77/4500 Active
Session ID: 11696
IPSEC FLOW: permit ip 192.168.88.0/255.255.252.0 192.168.238.128/255.255.255.224
Active SAs: 1318, origin: crypto map
Session status: DOWN
Peer: 3.11.178.77 port 500
IPSEC FLOW: permit ip 0.0.0.0/0.0.0.0 0.0.0.0/0.0.0.0
Active SAs: 0, origin: crypto map
Tunnel IDs
Tunnel-id Local Remote fvrf/ivrf Status
2 10.157.71.129/4500 3.11.178.77/4500 none/100 READY
Encr: AES-CBC, keysize: 256, PRF: SHA384, Hash: SHA384, DH Grp:16, Auth sign: PSK, Auth verify: PSK
Life/Active Time: 28800/7434 sec
3 10.157.71.129/4500 3.11.178.77/4500 none/100 READY
Life/Active Time: 28800/3692 sec
Show run
crypto ikev2 keyring if-ipsec3-ikev2-keyring
peer if-ipsec3-ikev2-keyring-peer
address 3.11.178.77
pre-shared-key 6 XXXXXXXXXXXXXXX (blanked out)
crypto ikev2 profile if-ipsec3-ikev2-profile
match identity remote address 3.11.178.77 255.255.255.255
identity local address 194.32.41.146
authentication remote pre-share
authentication local pre-share
keyring local if-ipsec3-ikev2-keyring
lifetime 28800
dpd 10 10 on-demand
no config-exchange request
crypto ipsec profile if-ipsec3-ipsec-profile
set security-association lifetime kilobytes disable
set security-association replay window-size 512
set transform-set if-ipsec3-ikev2-transform
set pfs group16
set ikev2-profile if-ipsec3-ikev2-profile
IPSEC show commands - Tunnel 3 is creating mutliple SAs
interface: Tunnel100003
Crypto map tag: Tunnel100003-head-0, local addr 10.157.71.129
protected vrf: 100
local ident (addr/mask/prot/port): (192.168.88.0/255.255.252.0/0/0)
remote ident (addr/mask/prot/port): (192.168.238.128/255.255.255.224/0/0)
current_peer 3.11.178.77 port 4500
PERMIT, flags={}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 14, #pkts decrypt: 14, #pkts verify: 14
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: 10.157.71.129, remote crypto endpt.: 3.11.178.77
plaintext mtu 1422, path mtu 1500, ip mtu 1500, ip mtu idb TenGigabitEthernet0/0/0.1000
current outbound spi: 0xCE632B24(3462605604)
PFS (Y/N): Y, DH group: group16
inbound esp sas:
spi: 0x4CE88AB9(1290308281)
transform: esp-256-aes esp-sha384-hmac ,
in use settings ={Tunnel UDP-Encaps, }
conn id: 30737, flow_id: HW:28737, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 370
Kilobyte Volume Rekey has been disabled
IV size: 16 bytes
replay detection support: Y replay window size: 512
Status: ACTIVE(ACTIVE)
spi: 0xB205554F(2986693967)
conn id: 30747, flow_id: HW:28747, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 374
IV size: 16 bytes
spi: 0xE65A1965(3864664421)
conn id: 30777, flow_id: HW:28777, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 388
IV size: 16 bytes
spi: 0xADAF427F(2913944191)
conn id: 30811, flow_id: HW:28811, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 402
IV size: 16 bytes
spi: 0xED31A470(3979453552)
conn id: 30833, flow_id: HW:28833, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 416
IV size: 16 bytes
spi: 0xF6B02A9C(4138740380)
conn id: 30849, flow_id: HW:28849, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 429
IV size: 16 bytes
spi: 0xBBF47A47(3153361479)
conn id: 30875, flow_id: HW:28875, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 443
IV size: 16 bytes
spi: 0xC0268BF1(3223751665)
conn id: 30905, flow_id: HW:28905, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 459
IV size: 16 bytes
spi: 0xB511C33D(3037840189)
conn id: 30943, flow_id: HW:28943, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 475
IV size: 16 bytes
spi: 0x1C87AB95(478653333)
conn id: 30955, flow_id: HW:28955, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 480
IV size: 16 bytes
spi: 0x1176129(18309417)
conn id: 30981, flow_id: HW:28981, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 494
IV size: 16 bytes
spi: 0x447DD305(1149096709)
conn id: 31009, flow_id: HW:29009, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 508
IV size: 16 bytes
spi: 0xC0811DC3(3229687235)
conn id: 31069, flow_id: HW:29069, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 539
IV size: 16 bytes
spi: 0xA1DF740E(2715776014)
conn id: 31115, flow_id: HW:29115, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 556
IV size: 16 bytes
spi: 0xAF8408D9(2944665817)
conn id: 31129, flow_id: HW:29129, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 563
IV size: 16 bytes
spi: 0x394997F7(961124343)
conn id: 31175, flow_id: HW:29175, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 582
IV size: 16 bytes
spi: 0x4844C1AA(1212465578)
conn id: 31213, flow_id: HW:29213, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 599
IV size: 16 bytes
spi: 0x7ED31C12(2127764498)
conn id: 31241, flow_id: HW:29241, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 614
IV size: 16 bytes
spi: 0x9BB21B8B(2612140939)
conn id: 31251, flow_id: HW:29251, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 617
IV size: 16 bytes
spi: 0x3B262ADD(992357085)
conn id: 31293, flow_id: HW:29293, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 641
IV size: 16 bytes
spi: 0x58676DA5(1483173285)
conn id: 31325, flow_id: HW:29325, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 655
IV size: 16 bytes
spi: 0x5D51C13A(1565638970)
conn id: 31345, flow_id: HW:29345, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 669
IV size: 16 bytes
spi: 0x2B95354F(731198799)
conn id: 31365, flow_id: HW:29365, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 677
IV size: 16 bytes
spi: 0x85AC336A(2242655082)
conn id: 31401, flow_id: HW:29401, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 696
IV size: 16 bytes
spi: 0xA5FA2E5F(2784636511)
conn id: 31449, flow_id: HW:29449, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 715
IV size: 16 bytes
spi: 0x4A4D4F9A(1246580634)
conn id: 31469, flow_id: HW:29469, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 725
IV size: 16 bytes
spi: 0xF0AECC51(4037987409)
conn id: 31511, flow_id: HW:29511, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 748
IV size: 16 bytes
spi: 0xCC8B18EB(3431667947)
conn id: 31545, flow_id: HW:29545, sibling_flags FFFFFFFF80000048, crypto map: Tunnel100003-head-0
sa timing: remaining key lifetime (sec): 765
IV size: 16 bytes
protected vrf: 100
local ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
remote ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
current_peer 3.11.178.77 port 500
PERMIT, flags={origin_is_acl,ipsec_sa_request_sent}
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#send errors 260563, #recv errors 0
plaintext mtu 1500, path mtu 1500, ip mtu 1500, ip mtu idb TenGigabitEthern et0/0/0.1000
current outbound spi: 0x0(0)
PFS (Y/N): N, DH group: none
inbound esp sas:
Any ideas cause on this?
Solved! Go to Solution.
01-15-2024 06:19 AM - edited 01-15-2024 06:25 AM
protected vrf: 100
there is something wrong
the IPSec for Tunnel not use proxy it must appear as 0.0.0.0
what is other Peer Vendor is it palo Azure ?
MHM
01-15-2024 02:58 AM
Can you share the tunnel config
MHM
01-15-2024 03:46 AM
Which show command/s would display the correct tunnel config?
interface Tunnel100003
vrf forwarding 100
ip address 169.254.14.66 255.255.255.252
ip mtu 1500
ip tcp adjust-mss 1379
tunnel source 10.157.71.129
tunnel mode ipsec ipv4
tunnel destination 3.11.178.77
tunnel path-mtu-discovery
tunnel protection ipsec profile if-ipsec3-ipsec-profile
01-15-2024 03:49 AM
Debug output
Jan 15 11:47:54.461: IKEv2:(SESSION ID = 11696,SA ID = 3):Sending Packet [To 3.11.178.77:4500/From 10.157.71.129:4500/VRF i0:f0]
Initiator SPI : A98608C628530D34 - Responder SPI : 83DC8E7D7801C6D4 Message id: 54694
IKEv2 CREATE_CHILD_SA Exchange RESPONSE
Payload contents:
ENCR
Jan 15 11:47:54.462: IKEv2-ERROR:(SESSION ID = 11696,SA ID = 3):: Create child exchange failed
Jan 15 11:47:54.462: IKEv2:(SESSION ID = 11696,SA ID = 3):Multiple same IPSec SA create failed
Jan 15 11:47:54.463: IKEv2:(SESSION ID = 11696,SA ID = 3):Abort exchange
Jan 15 11:47:54.988: IKEv2:(SESSION ID = 11696,SA ID = 3):Received Packet [From 3.11.178.77:4500/To 10.157.71.129:4500/VRF i0:f0]
Initiator SPI : A98608C628530D34 - Responder SPI : 83DC8E7D7801C6D4 Message id: 1019
Payload contents:
SA N KE TSi TSr
Jan 15 11:47:54.989: IKEv2:(SESSION ID = 11696,SA ID = 3):Processing any notify-messages in child SA exchange
Jan 15 11:47:54.989: IKEv2:(SESSION ID = 11696,SA ID = 3):Validating create child message
Jan 15 11:47:54.989: IKEv2:(SESSION ID = 11696,SA ID = 3):Processing CREATE_CHILD_SA exchange
Jan 15 11:47:54.989: IKEv2:(SESSION ID = 11696,SA ID = 3):IPSec policy validate request sent for profile if-ipsec3-ikev2-profile with psh index 3.
Jan 15 11:47:54.989: IKEv2:(SESSION ID = 11696,SA ID = 3):(SA ID = 3):[IPsec -> IKEv2] Callback received for the validate proposal - PASSED.
Jan 15 11:47:54.989: IKEv2:(SESSION ID = 11696,SA ID = 3):Checking for PFS configuration
Jan 15 11:47:54.989: IKEv2:(SESSION ID = 11696,SA ID = 3):PFS configured, DH group 16
Jan 15 11:47:54.989: IKEv2:(SESSION ID = 11696,SA ID = 3):[IKEv2 -> Crypto Engine] Computing DH secret key, DH Group 16
Jan 15 11:47:54.991: IKEv2:(SESSION ID = 11696,SA ID = 3):Request queued for computation of DH secret
Jan 15 11:47:54.996: IKEv2:(SESSION ID = 11696,SA ID = 3):(SA ID = 3):[Crypto Engine -> IKEv2] DH key Computation PASSED
Jan 15 11:47:54.996: IKEv2:(SESSION ID = 11696,SA ID = 3):Checking if IKE SA rekey
Jan 15 11:47:54.996: IKEv2:(SESSION ID = 11696,SA ID = 3):Load IPSEC key material
Jan 15 11:47:54.996: IKEv2:(SESSION ID = 11696,SA ID = 3):(SA ID = 3):[IKEv2 -> IPsec] Create IPsec SA into IPsec database
Jan 15 11:47:55.017: IKEv2:(SESSION ID = 11696,SA ID = 3):(SA ID = 3):[IPsec -> IKEv2] Creation of IPsec SA into IPsec database PASSED
Jan 15 11:47:55.017: IKEv2:(SESSION ID = 11696,SA ID = 3):IKEV2 SA created; inserting SA into database. SA lifetime timer (28800 sec) started
Jan 15 11:47:55.147: IKEv2:(SESSION ID = 11696,SA ID = 3):Received Packet [From 3.11.178.77:4500/To 10.157.71.129:4500/VRF i0:f0]
Initiator SPI : A98608C628530D34 - Responder SPI : 83DC8E7D7801C6D4 Message id: 54695
IKEv2 CREATE_CHILD_SA Exchange REQUEST
Payload contents:
SA N KE TSi TSr
Jan 15 11:47:55.147: IKEv2:(SESSION ID = 11696,SA ID = 3):Validating create child message
Jan 15 11:47:55.148: IKEv2:(SESSION ID = 11696,SA ID = 3):Check for create child response message type
Jan 15 11:47:55.148: IKEv2:(SESSION ID = 11696,SA ID = 3):Processing CREATE_CHILD_SA exchange
Jan 15 11:47:55.148: IKEv2:(SESSION ID = 11696,SA ID = 3):IPSec policy validate request sent for profile if-ipsec3-ikev2-profile with psh index 3.
Jan 15 11:47:55.148: IKEv2:(SESSION ID = 11696,SA ID = 3):(SA ID = 3):[IPsec -> IKEv2] Callback received for the validate proposal - PASSED.
Jan 15 11:47:55.148: IKEv2:Checking for duplicate IPsec SA with same proxies
Jan 15 11:47:55.149: IKEv2-ERROR:IPsec SA with same proxies already exists
Jan 15 11:47:55.150: IKEv2-ERROR:(SESSION ID = 11696,SA ID = 3):: IPsec SA with same proxies already exists
Jan 15 11:47:55.150: IKEv2:(SESSION ID = 11696,SA ID = 3):Sending temporary failure notify
Jan 15 11:47:55.150: IKEv2:(SESSION ID = 11696,SA ID = 3):Building packet for encryption.
Payload contents:
NOTIFY(TEMPORARY FAILURE)
Jan 15 11:47:55.150: IKEv2:(SESSION ID = 11696,SA ID = 3):Sending Packet [To 3.11.178.77:4500/From 10.157.71.129:4500/VRF i0:f0]
protected vrf: 100
MHM
01-15-2024 06:27 AM
01-15-2024 06:29 AM
You are so so welcome
MHM
