WSA Sizing help for 40000 users
p.s.arun2020
Level 4
Level 4
Dear All,
We have a requirement from a customer who has 40000 users and is looking for a web proxy solution. Please advise on how to size a WSA solution appropriately for the customer.
Arun
Valter Da Costa
Couple of options, Arun.
www.cisco.com/go/pdihelpdesk
That team can assist with sizing.
Contact a Cisco CSE (Consulting System Engineer) in your region. If you drop me an email (vdacosta@cisco.com) I can assist you in finding that resource for you.
Use our tool at :http://fwm.cisco.com
In that http://fwm.cisco.com/ site you will also be able to download our Sizing Guide.
I hope that helps.
-Valter
Thanks Valter! For your prompt response.
Arun P S
Should be https://fwm.cisco.com
Also, in the sizing calculator, what does RPS stand for ? ....something peak sessions?
RPS stands for Request per Second. So if the customer already have a Proxy or some tool that can provide the Peak HTTP/S request per second, that will help in sizing. Other wise go with the default suggested value
