12-22-2014 08:15 AM - edited 07-05-2021 02:09 AM
Hello.
I try to load the Autonomous Ios in the flash. The Ios version is ap1g2-k9w7-mx.153-3.JAB but dont start the Ap.
I load this Ios with tftp conection but in the statup I see this error:The system is unable to boot automatically. The BOOT environment variable needs to be set to a bootable.
I try with Ios most old , but I see the same error. Only work with the lightweight Ios.
Thank´s.
Solved! Go to Solution.
12-23-2014 01:36 AM
Try downloading the image again and verify that the MD5 hash matches. You should be able to delete the other images in flash and use the TFTP method to upload the image again. The rule of thumb is that if there is an autonomous image on CCO, then it is supported by TAC and that means it should work.
-Scott
12-22-2014 08:38 AM
Try to set the boot following this guide. It's old, but still have the same process. Look at step 8 where it tells you how to set the boot.
https://supportforums.cisco.com/document/56156/access-point-rommon-recovery-ap-prompt-recovery-example
-Scott
12-22-2014 08:42 AM
Here are various ways of converting if you don't have it already
12-22-2014 09:41 AM
Thanks for your Answer.
I try now the process again following youtube video.
The only diferent with my process is the tftp server. I work with solarisWinds.
Now I try with tftpd32
I thinck the error is in the sending image ios.
When I finish with this test, I will write.
12-22-2014 09:52 AM
I have the same problem.
I write the mesages process.
extracting ap1g2-k9w7-m.153-3.jab...
deleting target version:flash:/ap1g2-k9w7-mx.153-3JAB...done
new software image instaled in falsh:/ap1g2-k9w7-mx.153-3JAB
configuring systeam to use new image...done
requested system reload in progress...download took about 4289 seconds
loading"flash:/ap1g2-k9w7-mx.153-3.JAB/ap1g2-k9w7-mx.153-3.JAB...###############
The system is unable to boot automatically. The BOOT enviroment variable needs to be set to a bootable image.
ap:
If I try with the lightweight image Ios, work good.
This AP only work with lightweight IOs???? This is my fear.
12-22-2014 10:00 AM
Did you reference this on how to set the boot?
-Scott
12-23-2014 12:44 AM
Hi.
Yes, I read this reference and I don´t see nothing.
In my case, I put ap: set and I see this.
BOOT:FLASH:/ap1g2-k9w7-mx.153-3.JAB/ap1g2-k9w7-mx.153-3.JAB
DEFAULT_ROUTER=10.0.0.1
IP_ADDR=10.0.01
NETMASK=255.255.255.224
RELOAD_REASON=41
My question is. The ios ap1g2-k9w7-mx.153-3.JAB is valid to AIR-CAP702I-E-K9? Because I don´t have problems with the Ios ap1g2-k9w8, only have problems with ap1g2-k9w7.
12-23-2014 01:36 AM
-Scott
12-23-2014 02:15 AM
Thanks Scott.
The error is mi image Ios, is corrupt or model diferent. I will dowload the image
again.
01-10-2018 07:02 PM
I have AIR-CAP702I-F-K9 with ap1g1-rcvk9w8-mx 15.2(4)JA.
How to set this AP from LLW to Autonomous ?
I already download the autonomous image.
01-10-2018 11:51 PM
