Aironet 1562i Outdoor AP - Bridge
Is101008
Level 4
Level 4
we want to extend for a customer the corporate network to another building just on the opposit side of the road (50 meters distance). We are thiking about installing 2 1562i APs as Point to Point Bridge. Both APs can me mounted on the roof and have direct line of sight.
What datarate can i expect ? Does anybody have experience with this AP in Bridge mode ? As i said the distance is not very far.
Greetings
Rafael E
You can use the following link to plan your link.
Use the "coverage" tab.
Ux AP Planner (Cloud-edition) v3.15
Rafael
Saludos,
Rafael - TAC
ammahend
Along with the planner, make sure you get mesh image on AP In order to create a RAP-MAP mesh (bridge), make sure you have 2 additional license on WLC to accommodate the APs, remember 1560s do not support autonomous image, so you can't create a traditional autonomous bridge. make sure you get lightening arrest and other mounting accessories, refer to 1560 ordering guide you will find all the information.
-hope this helps-
