Antenna extension
ammahend
Hi community, what’s the best way to extend air-ant-2513 by 20 feet
-hope this helps-
Leo Laohoo
Move the AP by 20 feet.
AP can not be moved.
the AP is 9124AXE, which is N female I think, AIR-ANT2513 is also N-female, so I was thinking I will do 9124AXE->AIR-CAB010LL-N-> N-female to female converter -> AIR-CAB010LL-N->AIR-ANT2513
Any thoughts ? experience ?
-hope this helps-
Have you think about these AccelTex ones?
I use to use them and they give excellent result.
Jesus
I did, my customer is adamant on Cisco, the only other variation I did was 25 feet cable(AIR-CAB025HZ-N=), So they have both options, I was hoping to get some feedback on performance if someone has used this antenna in a similar way.
-hope this helps-
