LAP is not broadcasting the SSID
yasseryy
I am doing the default startup configuration , LAPs successfuly joined the WLC( 5508) . The 802.11 radio are all up ,  SSID is broadcasting , however, I an not able to see it.
See the below show commands
(Cisco Controller) >show advanced 802.11a summary
Member RRM Information
AP Name                          MAC Address       Slot Admin    Oper        Channel            TxPower
AP0896.AD9D.07EC                 2c:5a:0f:1a:6c:e0  1   ENABLED  UP          36*                *1/7 (18 dBm)
AP0896.AD9D.0FB8                 2c:5a:0f:40:20:a0  1   ENABLED  UP          36*                *1/7 (18 dBm)
APA03D.6F57.E188                 2c:5a:0f:3f:b9:20  1   ENABLED  UP          36*                *1/7 (18 dBm)
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.2.110.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.95.16
Firmware Version................................. FPGA 1.7, Env 1.8, USB console                                         2.2
Build Type....................................... DATA + WPS
System Name...................................... Cisco_98:82:64
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. SSO
IP Address....................................... 10.32.1.1
IPv6 Address..................................... ::
Last Reset....................................... Watchdog reset
System Up Time................................... 0 days 1 hrs 29 mins 57 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Show sysinfo
--More-- or (q)uit
Configured Country............................... SA  - Saudi Arabia
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +42 C
External Temperature............................. +30 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ 00:F2:8B:98:82:60
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 500
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1/SHA2
(Cisco Controller) >show wlan summary
WLAN ID  WLAN Profile Name / SSID               Status    Interface Name        PMIPv6 Mobility
1        PRof1 / Test                           Enabled   management            none
(Cisco Controller) >show ap config general AP0896.AD9D.07EC
Cisco AP Identifier.............................. 0
Cisco AP Name.................................... AP0896.AD9D.07EC
Country code..................................... SA  - Saudi Arabia
Regulatory Domain allowed by Country............. 802.11bg:-AE    802.11a:-E
AP Country code.................................. SA  - Saudi Arabia
AP Regulatory Domain............................. -E
Switch Port Number .............................. 1
MAC Address...................................... 08:96:ad:9d:07:ec
IP Address Configuration......................... DHCP
IP Address....................................... 10.32.1.107
IP NetMask....................................... 255.255.255.0
Gateway IP Addr.................................. 10.32.1.229
NAT External IP Address.......................... None
CAPWAP Path MTU.................................. 1485
DHCP Release Override............................ Disabled
Telnet State..................................... Globally Disabled
Ssh State........................................ Globally Disabled
Cisco AP Location................................ default location
Cisco AP Floor Label............................. 0
Cisco AP Group Name.............................. default-group
Primary Cisco Switch Name........................
--More-- or (q)uit
Primary Cisco Switch IP Address.................. Not Configured
Secondary Cisco Switch Name......................
Secondary Cisco Switch IP Address................ Not Configured
Tertiary Cisco Switch Name.......................
Tertiary Cisco Switch IP Address................. Not Configured
Administrative State ............................ ADMIN_ENABLED
Operation State ................................. REGISTERED
Mirroring Mode .................................. Disabled
AP Mode ......................................... FlexConnect
Public Safety ................................... Disabled
AP SubMode ...................................... Not Configured
Rogue Detection ................................. Enabled
AP Vlan Trunking ................................ Disabled
Remote AP Debug ................................. Disabled
Logging trap severity level ..................... informational
Logging syslog facility ......................... kern
S/W  Version .................................... 8.2.110.0
Boot  Version ................................... 1.1.2.4
Mini IOS Version ................................ 0.0.0.0
Stats Reporting Period .......................... 30
Stats Collection Mode ........................... normal
LED State........................................ Enabled
PoE Pre-Standard Switch.......................... Disabled
--More-- or (q)uit
PoE Power Injector MAC Addr...................... Disabled
Power Type/Mode.................................. PoE/Medium Power (15.4 W)
Number Of Slots.................................. 2
AP Model......................................... AIR-AP2802E-E-K9
IOS Version...................................... 8.2.110.0
Reset Button..................................... Enabled
AP Serial Number................................. FDO21011EXB
AP Certificate Type.............................. Manufacture Installed
AP LAG Configuration Status ..................... Disabled
LAG Support for AP .............................. Yes
Native Vlan Inheritance: ........................ AP
FlexConnect Vlan mode :.......................... Disabled
FlexConnect Group................................ Not a member of any group
Group VLAN ACL Mappings
Group VLAN Name to Id Mappings
 Template in Modified State - apply it to see mappings
AP-Specific FlexConnect Policy ACLs :
L2Acl Configuration ............................. Not Available
FlexConnect Local-Split ACLs :
--More-- or (q)uit
WLAN ID   PROFILE NAME                       ACL                                 TYPE
 Flexconnect Central-Dhcp Values :
WLAN ID   PROFILE NAME                         Central-Dhcp      DNS Override      Nat-Pat     Type
Flex AVC visibility Configurations..............
WlanId  PROFILE NAME                     Inherit-level Visibility       Flex Avc-profile
FlexConnect Backup Auth Radius Servers :
 Primary Radius Server........................... Disabled
 Secondary Radius Server......................... Disabled
AP User Mode..................................... AUTOMATIC
AP User Name..................................... Cisco
AP Dot1x User Mode............................... Not Configured
AP Dot1x User Name............................... Not Configured
Cisco AP system logging host..................... 255.255.255.255
AP Up Time....................................... 0 days, 01 h 54 m 39 s
AP LWAPP Up Time................................. 0 days, 01 h 29 m 46 s
--More-- or (q)uit
Join Date and Time............................... Thu May  4 18:41:03 2017
Join Taken Time.................................. 0 days, 00 h 18 m 58 s
Memory Type...................................... DDR3
Memory Size...................................... 1030144 KBytes
CPU Type.........................................  ARMv7 Processor rev 1 (v7l)
Flash Type....................................... Onboard Flash
Flash Size....................................... 58368 KBytes
GPS Present...................................... NO
Ethernet Vlan Tag................................ Disabled
Ethernet Port Duplex............................. Full
Ethernet Port Speed.............................. Auto
AP Link Latency.................................. Disabled
Rogue Detection.................................. Enabled
AP TCP MSS Adjust................................ Disabled
Hotspot Venue Group.............................. Unspecified
Hotspot Venue Type............................... Unspecified
      DNS server IP ............................. Not Available
7 Replies 7
Ric Beeching
Level 7
Level 7
Can you do a show wlan 1 please? If you have more than 1 AP. is it affecting just this one AP? Is the WLAN potentially running in 802.11a mode only and your client is not 5GHz capable?
Ric
Please rate helpful / correct posts
Hello Ric,
This is affecting all APs ,  during the Auto Setup , I have enabled all the radios .. Below is show command :
WLAN Identifier.................................. 1
Profile Name..................................... PRof1
Network Name (SSID).............................. Test
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Client Profiling Status
    Radius Profiling ............................ Disabled
     DHCP ....................................... Disabled
     HTTP ....................................... Disabled
    Local Profiling ............................. Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
--More-- or (q)uit
ATF Policy....................................... 0
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 86400 seconds
User Idle Timeout................................ Disabled
Sleep Client..................................... disable
Sleep Client Timeout............................. 720 minutes
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... none
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ management
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
WLAN Layer2 ACL.................................. unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Tunnel Profile................................... Unconfigured
PMIPv6 Mobility Type............................. none
--More-- or (q)uit
    PMIPv6 MAG Profile........................... Unconfigured
    PMIPv6 Default Realm......................... Unconfigured
    PMIPv6 NAI Type.............................. Hexadecimal
    PMIPv6 MAG location.......................... WLC
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
--More-- or (q)uit
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... 802.1P (Tag=0)
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
      Interim Update............................. Enabled
      Interim Update Interval.................... 0
      Framed IPv6 Acct AVP ...................... Prefix
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Radius NAI-Realm................................. Disabled
Mu-Mimo.......................................... Enabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
--More-- or (q)uit
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web Authentication Timeout.................... 300
   Web-Passthrough............................... Disabled
   Mac-auth-server............................... 0.0.0.0
   Web-portal-server............................. 0.0.0.0
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   FlexConnect Central Association............... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   flexconnect PPPoE pass-through................ Disabled
   flexconnect local-switching IP-source-guar.... Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
--More-- or (q)uit
   Client MFP.................................... Optional but inactive (WPA2 no                             t configured)
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
   Eap-params.................................... Not Applicable
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Split Tunnel Configuration
    Split Tunnel................................. Disabled
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
802.11v Directed Multicast Service............... Disabled
802.11v BSS Max Idle Service..................... Enabled
802.11v BSS Transition Service................... Disabled
802.11v BSS Transition Disassoc Imminent......... Disabled
--More-- or (q)uit
802.11v BSS Transition Disassoc Timer............ 200
802.11v BSS Transition OpRoam Disassoc Timer..... 40
DMS DB is empty
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Universal Ap Admin............................... Disabled
 Mobility Anchor List
 WLAN ID     IP Address            Status                             Priority
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Local Policy
Priority  Policy Name
Lync State ...................................... Disabled
Audio QoS Policy................................. Silver
--More-- or (q)uit
Video QoS Policy................................. Silver
App-Share QoS Policy............................. Silver
File Transfer QoS Policy......................... Silver
(Cisco Controller) >?
clear          Clear selected configuration elements.
config         Configure switch options and settings.
Thanks.. it all looks good to me and the code is compatible with the 2800 series.
What antennas have you attached to the APs seeing as they are External APs?
Cheers,
Ric
Hello Ric,
Thank for your reply. Is there a way to check the Antenna from the config or show commands  because I am remotely connected to the site.
Also, I notice the below traps. The radio keep disabling after a while , and I have to enable and disable the radio for it to work again.
Trap Log
Log System Time Trap
0 Sat May 6 10:15:00 2017 RF Manager updated TxPower for Base Radio MAC: 2c:5a:0f:3f:b9:20 and Radio Type: 802.11bg New Tx Power is: 2
1 Sat May 6 10:15:00 2017 RF Manager updated TxPower for Base Radio MAC: 2c:5a:0f:3f:b9:20 and Radio Type: 802.11a New Tx Power is: 2
2 Sat May 6 10:15:00 2017 RF Manager updated TxPower for Base Radio MAC: 2c:5a:0f:40:20:a0 and Radio Type: 802.11bg New Tx Power is: 2
3 Sat May 6 10:15:00 2017 RF Manager updated TxPower for Base Radio MAC: 2c:5a:0f:40:20:a0 and Radio Type: 802.11a New Tx Power is: 2
4 Sat May 6 10:15:00 2017 RF Manager updated TxPower for Base Radio MAC: 2c:5a:0f:1a:6c:e0 and Radio Type: 802.11bg New Tx Power is: 4
5 Sat May 6 10:15:00 2017 RF Manager updated TxPower for Base Radio MAC: 2c:5a:0f:1a:6c:e0 and Radio Type: 802.11a New Tx Power is: 4
6 Sat May 6 10:06:15 2017 AP MAC: 2c:5a:0f:3f:b9:20, AP Name: APA03D.6F57.E188, Power Type/Mode: PoE/Medium Power.
7 Sat May 6 10:06:15 2017 AP MAC: 2c:5a:0f:40:20:a0, AP Name: AP0896.AD9D.0FB8, Power Type/Mode: PoE/Medium Power.
8 Sat May 6 10:06:15 2017 AP MAC: 2c:5a:0f:1a:6c:e0, AP Name: AP0896.AD9D.07EC, Power Type/Mode: PoE/Medium Power.
9 Sat May 6 10:05:00 2017 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:2c:5a:0f:3f:b9:20 Cause=Unknown Reset Status:NA
10 Sat May 6 10:05:00 2017 AP's Interface:0(802.11abgn) Operation State Down: Base Radio MAC:2c:5a:0f:3f:b9:20 Cause=Unknown Reset Status:NA
11 Sat May 6 10:05:00 2017 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:2c:5a:0f:40:20:a0 Cause=Unknown Reset Status:NA
12 Sat May 6 10:05:00 2017 AP's Interface:0(802.11abgn) Operation State Down: Base Radio MAC:2c:5a:0f:40:20:a0 Cause=Unknown Reset Status:NA
13 Sat May 6 10:04:59 2017 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:2c:5a:0f:1a:6c:e0 Cause=Unknown Reset Status:NA
14 Sat May 6 10:04:59 2017 AP's Interface:0(802.11abgn) Operation State Down: Base Radio MAC:2c:5a:0f:1a:6c:e0 Cause=Unknown Reset Status:NA
15 Sat May 6 10:04:58 2017 AP 'APA03D.6F57.E188', MAC: 2c:5a:0f:3f:b9:20 disassociated previously due to AP Reset. Uptime: 0 days, 00 h 02 m 42 s . Reason: .
16 Sat May 6 10:04:57 2017 AP 'AP0896.AD9D.0FB8', MAC: 2c:5a:0f:40:20:a0 disassociated previously due to AP Reset. Uptime: 0 days, 00 h 02 m 41 s . Reason: .
17 Sat May 6 10:04:57 2017 AP 'AP0896.AD9D.07EC', MAC: 2c:5a:0f:1a:6c:e0 disassociated previously due to AP Reset. Uptime: 0 days, 00 h 02 m 40 s . Reason: .
18 Sat May 6 08:39:57 2017 AP Disassociated. Base Radio MAC:2c:5a:0f:1a:6c:e0 ApName - AP0896.AD9D.07EC
19 Sat May 6 08:39:55 2017 AP Disassociated. Base Radio MAC:2c:5a:0f:40:20:a0 ApName - AP0896.AD9D.0FB8
20 Sat May 6 08:39:55 2017 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:2c:5a:0f:40:20:a0 Cause=Heartbeat Timeout Status:NA
21 Sat May 6 08:39:55 2017 AP's Interface:0(802.11abgn) Operation State Down: Base Radio MAC:2c:5a:0f:40:20:a0 Cause=Heartbeat Timeout Status:NA
22 Sat May 6 08:39:46 2017 AP Disassociated. Base Radio MAC:2c:5a:0f:3f:b9:20 ApName - APA03D.6F57.E188
23 Sat May 6 08:39:46 2017 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:2c:5a:0f:3f:b9:20 Cause=Heartbeat Timeout Status:NA
24 Sat May 6 08:39:46 2017 AP's Interface:0(802.11abgn) Operation State Down: Base Radio MAC:2c:5a:0f:3f:b9:20 Cause=Heartbeat Timeout Status:NA
25 Fri May 5 11:56:06 2017 RF Manager updated TxPower for Base Radio MAC: 2c:5a:0f:1a:6c:e0 and Radio Type: 802.11bg New Tx Power is: 3
26 Fri May 5 11:56:06 2017 RF Manager updated TxPower for Base Radio MAC: 2c:5a:0f:1a:6c:e0 and Radio Type: 802.11a New Tx Power is: 3
27 Fri May 5 11:47:22 2017 AP MAC: 2c:5a:0f:1a:6c:e0, AP Name: AP0896.AD9D.07EC, Power Type/Mode: PoE/Medium Power.
28 Fri May 5 11:46:06 2017 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:2c:5a:0f:1a:6c:e0 Cause=Unknown Reset Status:NA
29 Fri May 5 11:46:06 2017 AP's Interface:0(802.11abgn) Operation State Down: Base Radio MAC:2c:5a:0f:1a:6c:e0 Cause=Unknown Reset Status:NA
30 Fri May 5 11:46:03 2017 AP 'AP0896.AD9D.07EC', MAC: 2c:5a:0f:1a:6c:e0 disassociated previously due to AP Reset. Uptime: 0 days, 00 h 02 m 40 s . Reason: .
31 Fri May 5 11:42:13 2017 AP Disassociated. Base Radio MAC:2c:5a:0f:1a:6c:e0 ApName - AP0896.AD9D.07EC
32 Fri May 5 11:42:12 2017 AP with MAC: 2c:5a:0f:1a:6c:e0(AP0896.AD9D.07EC) mode changed from Remote to Local.
33 Fri May 5 07:06:28 2017 RF Manager updated TxPower for Base Radio MAC: 2c:5a:0f:1a:6c:e0 and Radio Type: 802.11bg New Tx Power is: 2
34 Fri May 5 07:06:28 2017 RF Manager updated TxPower for Base Radio MAC: 2c:5a:0f:1a:6c:e0 and Radio Type: 802.11a New Tx Power is: 2
35 Fri May 5 06:55:01 2017 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:2c:5a:0f:1a:6c:e0 Cause=Unknown Reset Status:NA
36 Fri May 5 06:55:01 2017 AP's Interface:0(802.11abgn) Operation State Down: Base Radio MAC:2c:5a:0f:1a:6c:e0 Cause=Unknown Reset Status:NA
37 Fri May 5 06:55:01 2017 AP 'AP0896.AD9D.07EC', MAC: 2c:5a:0f:1a:6c:e0 disassociated previously due to AP Reset. Uptime: 0 days, 12 h 38 m 48 s . Reason: .
38 Fri May 5 06:54:45 2017 AP Disassociated. Base Radio MAC:2c:5a:0f:1a:6c:e0 ApName - AP0896.AD9D.07EC
39 Fri May 5 06:54:45 2017 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:2c:5a:0f:1a:6c:e0 Cause=New Discovery Status:NA
40 Fri May 5 06:54:45 2017 AP's Interface:0(802.11abgn) Operation State Down: Base Radio MAC:2c:5a:0f:1a:6c:e0 Cause=New Discovery
You would need someone to take a picture of the AP so you can work out the antennas as it can't be found via commands unfortunately!
I think your problem is this
Your AP requires 802.3at PoE and it is only being provided with 802.3af PoE from the switch.This means the AP does not have enough power to keep all the radios up and shuts down the 5GHz. One option would be to disable the 2.4GHz radio.
Is your SSID 5GHz only?
Ric
I would check 802.11a/b network is enabled. "show 802.11a" and "show 802.11b" command verify this.
Also noticed AP in FlexConnect mode, hope you configure switchports as trunk to support it with necessary vlan mapping.
I would suggest 8.2.151.0 code, if you have a chance to upgrade.
Rasika
Hello Rasika,
From the show command ,I can see 802.11a and 802.11b are enabled. I changed the flex mode on the AP to local mode.
See the show commands :
(Cisco Controller) >show 802.11a
802.11a Network.................................. Enabled
11acSupport...................................... Enabled
11nSupport....................................... Enabled
      802.11a Low Band........................... Enabled
      802.11a Mid Band........................... Enabled
      802.11a High Band.......................... Enabled
802.11a Operational Rates
    802.11a 6M Rate.............................. Mandatory
    802.11a 9M Rate.............................. Supported
    802.11a 12M Rate............................. Mandatory
    802.11a 18M Rate............................. Supported
    802.11a 24M Rate............................. Mandatory
    802.11a 36M Rate............................. Supported
    802.11a 48M Rate............................. Supported
    802.11a 54M Rate............................. Supported
(Cisco Controller) >show 802.11b
802.11b Network.................................. Enabled
11gSupport....................................... Enabled
802.11b/g Operational Rates
    802.11b/g 1M Rate............................ Mandatory
    802.11b/g 2M Rate............................ Mandatory
    802.11b/g 5.5M Rate.......................... Mandatory
    802.11b/g 11M Rate........................... Mandatory
    802.11g 6M Rate.............................. Supported
    802.11g 9M Rate.............................. Supported
    802.11g 12M Rate............................. Supported
    802.11g 18M Rate............................. Supported
    802.11g 24M Rate............................. Supported
Cisco AP Identifier.............................. 5
IP Address....................................... 10.32.1.102
Gateway IP Addr.................................. 10.32.1.225
--More-- or (q)uit
AP Mode ......................................... Local
--More-- or (q)uit
AP Up Time....................................... 0 days, 11 h 49 m 43 s
AP LWAPP Up Time................................. 0 days, 11 h 47 m 03 s
Join Date and Time............................... Sat May  6 10:04:57 2017
Join Taken Time.................................. 0 days, 00 h 02 m 39 s
--More-- or (q)uit
Still I am not able to see the broadcastedSSID !!
