WLSE 2.13 and import Firmware
gauthrayj
I have got soem troubles to import firmware in me WLSE 2.13
I want to upgrade my A/P's in IOS 12.3(7)JA3 but when I try to import from my desktop the ios tar file (for 1200 and 1130) it says to me "import failed" or "Imported file is not a valid image." but I am sure it is good because I download it on some ap.
If I try to import the ios from cisco.com, it the same error message :"Imported file is not a valid image."
Does anybody have the same trouble ?
rmushtaq
Level 8
Level 8
I just tested this by downloading the 12.3(7)JA3 IOS for 1130 and imported it from my desktop with no issues. Try downloading the file again from CCO to make sure that it is not bad. Also, ensure that while importing, you're selecting the correct Device Type from the pull-down menu. If you have an AP 1231 or AP1232, select AP1210. For 1130, select AP1130.
