ios xrv 9000 srv6 assign more than one locator
xiaodong liao
ios xrv 9000 version 7.1.1
I want to configure SRv6 IS-IS Flexible Algorithm with those command:
Router(config)# segment-routing srv6
Router(config-srv6)# locators
Router(config-srv6-locators)# locator Loc1-BE // best-effort
Router(config-srv6-locator)# prefix 2001:db8:0:a2::/64
Router(config-srv6-locator)# exit
Router(config-srv6-locators)# locator Loc1-LL // low latency
Router(config-srv6-locator)# prefix 2001:db8:1:a2::/64
Router(config-srv6-locator)# algorithm 128
when I commit, it failed with error: !!% Operation not supported: Max number of locators already configured
is that indicate the xrv platform only support one srv6 locator?
Ariyarathna
Did you found any solution ?
