openstack service create
detaevo@cisco.com
Hi guys,
In fact i'm starting using Openstack **Kilo** and get in trouble following the documentation (page 36) with the following command:
root@controller:/var/log/keystone# openstack service create
root@controller:/var/log/keystone# openstack service create \
> --name keystone --description "OpenStack Identity" identity
****usage: openstack service create [-h] [-f {shell,table}] [-c COLUMN]
                                [--variable VARIABLE] [--prefix PREFIX] --type
                                <service-type>
                                [--description <service-description>]
                                <service-name>**
openstack service create: error: argument --type is required
root@controller:/var/log/keystone#**
Anything relating to Openstack client API version ? Do you have any experience with this build ?
BR
Olivier
5 Replies 5
eckelcu
I'm not sure which document you refer to when you say "page 36", but it looks like you specified "name" instead of "type" parameter. Try this instead:
openstack service create --type identity --description "OpenStack Identity" identity
Hi, i was talking about this doc http://docs.openstack.org/kilo/install-guide/install/apt/content/ch_overview.html
BR
Olivier
Olivier Detaevernier
CONSULTING SYSTEMS ENGINEER.SP SALES
Global Service Providers - Emear
detaevo@cisco.com<mailto:detaevo@cisco.com>
Phone: +33 23 788 3733
Mobile: +33 6 73 99 21 70
Cisco.com<http://www.cisco.com>
Think before you print.
This email may contain confidential and privileged material for the sole use of the intended recipient. Any review, use, distribution or disclosure by others is strictly prohibited. If you are not the intended recipient (or authorized to receive for the recipient), please contact the sender by reply email and delete all copies of this message.
Please click here<http://www.cisco.com/web/about/doing_business/legal/cri/index.html> for Company Registration Information.
I see. Try using:
and see if that works.
Yep, it got another issue now
root@controller:/var/log/keystone# openstack service create --type identity --description "OpenStack Identity" identity
INFO: urllib3.connectionpool Starting new HTTP connection (1): controller
ERROR: cliff.app Internal Server Error (HTTP 500)
BR
Olivier
roagarwa
Someone else encountered a similar issue and has offered a solution here - http://stackoverflow.com/questions/30844010/keystone-connection-fail
I have not tried it but assuming you have a Ubuntu environment, might want to try the steps below as suggested in the link -
nano /etc/apt/sources.list.d/cloudarchive-kilo.list
deb http://ubuntu-cloud.archive.canonical.com/ubuntu trusty-updates/kilo main
apt-get update && apt-get dist-upgrade
