09-20-2017 02:13 PM - edited 03-08-2019 12:06 PM
I must be blind today because I cannot find any information about this. Can someone point me in the right direction?
Solved! Go to Solution.
09-20-2017 05:20 PM
Cory,
It is the same as Catalyst 3850.
Power cycle the switch. Immediatly press and hold the Mode button. Hold the button till the Status LED will go amber. Then on the console you should be in Boot Loader.
Switch:
Add the following variables.
Switch: SWITCH_IGNORE_STARTUP_CFG=1
Then boot the switch.
Switch: boot
Once the switch has booted you can copy the saved config back into the running config.
Switch# copy start runn
Next set your password(s). Finally we want to remove the variables we set while in Boot Loader.
Switch# no system ignore startupconfig switch all
Save your new config.
Switch# copy runn start
Let me know if you have any further questions.
Minhaj Uddin
09-20-2017 05:20 PM
Cory,
Switch:
Switch: boot
Minhaj Uddin
09-21-2017 11:12 AM
Worked perfectly. Thank you!
12-07-2017 11:42 PM
Thanks...I tried this and working fine.
07-26-2018 02:07 PM
Pressing and holding the mode button does nothing for me, i have read other threads and the solution that has worked for me is after power cycling the switch just start pressing the mode button multiple times until you see "switch:"
09-14-2018 06:44 AM
11-29-2018 10:31 AM
You must be running IOS XE (linux), in that case it's a little different, follow these steps:
Initializing Hardware...
System Bootstrap, Version 16.6.1r [FC1], RELEASE SOFTWARE (P)
Compiled Sat 07/15/2017 8:31:57.39 by rel
Current image running:
Primary Rommon Image
Last reset cause: SoftwareReload <---- Once you see this, start pressing and releasing the mode button 3 times
C9300-24U platform with 8388608 Kbytes of main memory
attempting to boot from [flash:packages.conf]
Located file packages.conf
Unable to load cat9k-rpboot.16.06.02b.SPA.pkg
Failed to boot file flash:user/packages.conf
ERROR: failed to boot from flash:packages.conf (Aborted) <--- will abort
switch:
switch: <---- ROMMON
Now issue these commands:
Switch: boot
If it shows you error issue the same "boot" command again.
Please rate helpful posts.
05-02-2019 12:10 AM
Earlier procedure of continuously pressing the mode button didn't worked. This one described by
09-26-2019 04:49 PM
03-12-2020 10:21 AM
the mode button press 3 times as described definitely works for 9300 48 UPoE - version 16.8.1r
03-29-2023 05:30 PM
This process helped me!
06-14-2019 06:52 AM
Thanks for sharing!
08-05-2020 11:47 AM
01-04-2021 04:18 PM
Anderbri -
Holding the mode button during bootup did not work for me either. Pressing mode during bootup did the trick.
Thank you.
04-21-2023 07:47 AM
same here, needed to press the mode button over and over, one steady press had no effect.....
