Python SSH devices
lAhmed Saadl
Dears,
 I am trying to run a code that could SSH list of devices and come back with data in an external file from these devices.
But, at the beginning I am facing some issues regarding netmiko and other features however I have already installed these functions. Could you please give a support hand?
Code:
from __future__ import print_function
from netmiko import ConnectHandler
import sys
import time
import select
import paramiko
import re
fd = open(r'C:\Test.txt','w')
old_stdout = sys.stdout
sys.stdout = fd
platform = 'cisco_ios'
username = 'admin'
password = 'cisco'
ip_add_file = open(r'C:\IPAddressList.txt','r')
for host in ip_add_file:
host = host.strip()
device = ConnectHandler(device_type=platform, ip=host, username=username, password=password)
output = device.send_command('terminal length 0')
output = device.send_command('enable')
print('##############################################################\n')
print('...................CISCO COMMAND SHOW RUN OUTPUT......................\n')
output = device.send_command('sh run')
print(output)
print('...................CISCO COMMAND SHOW IP INT BR OUTPUT......................\n')
output = device.send_command('sh ip int br')
print(output)
fd.close()
Error:
Traceback (most recent call last):
File "C:\Users\adam\PycharmProjects\test\testt.py", line 2, in <module>
ModuleNotFoundError: No module named 'netmiko'
Process finished with exit code 1
There is something wrong with your certificates, most probably an intermediate proxy server. Can you try this from a CMD window:
C:\Users\ahmed.mmsaad\PycharmProjects\test\.venv\Scripts\activate
pip install --trusted-host pypi.org --trusted-host files.pythonhosted.org netmiko
10 Replies 10
Marcel Zehnder
First you need to install netmiko:
pip install netmiko
Also, I think there are some other errors in your script. So, here is an example which should work for your usecase:
Your IPAddressList.txt file is assumed in the same directory as your script, the commands you want to execute are listed in the commands list. The script will print the output of each command for each device to the screen, and also writes the output to a file Output.txt in the same directory.
host_list = "IPAddressList.txt"
out_file = "Output.txt"
username = "admin"
password = "cisco"
commands = [
    "show run",
    "show ip int br"
with open(host_list, "r") as fo:
    hosts = [host.strip() for host in fo.readlines()]
with open(out_file, "w") as fo:
    for host in hosts:
        dev = {
            "device_type": "cisco_ios",
            "host": host,
            "username": username,
            "password": password,
        with ConnectHandler(**dev) as net_connect:
            for cmd in commands:
                print(f"=== Get {cmd} on {host} ===")
                output = net_connect.send_command(cmd)
                print(output)
                fo.write(f"=== Get {cmd} on {host} ===\n")
                fo.write(output)
Marcel
Hello Marcel,
Thanks I will try this, but netmiko is already installed (output: requirement already satisfied). But, I maybe have installed module in Python and run code with other PyCharm... Could you please guide how to install netmiko for PyCharm?
when I did is CMD path --> C:\windows\system32 ---> pip install netmiko.
But when I use PyCharm;
import sys
print (sys.executable)
my path is  C:\Users\adam\PycharmProjects\test\.venv\Lib\site-packages_virtualenv.py
PyCharm creates a python virtual environment. How to install packages into this environemnt is documented here:
https://www.jetbrains.com/guide/python/tutorials/getting-started-pycharm/installing-and-managing-python-packages/
Thank you Marcel. Could you please support in this showing error?
Thank you Marcel for that great effort. Appreciated, mate.
I just have a simple silly question if I have list of IPS and then I want the output to be separately for each of them in a file text what might be the change on the code?
Hi, this should wirte a file for each IP:
username = "admin"
password = "cisco"
commands = [
    "show run",
    "show ip int br"
for host in hosts:
    dev = {
        "host": host,
    with open(f"output_{host}.txt", "w") as fo:
                print(output)
                fo.write(output)
Hi.
How could I include a .txt file where all the commands are?
Marcel Zehnder
I don't use PyCharm but google[1] told me the above should also be possible directly in PyCharm:
File --> Settings --> Project: name_of_the_project --> Project Interpreter
Choose (double click) the package you want to update and the Available Packages will pop-up. There is a checkbox Options on the lower-left part of the window. Check that and enter
[1] https://www.appsloveworld.com/python/119/how-do-i-add-the-trusted-host-in-pycharm-package-install
You should consider using DevNetUI. It makes tasks like this simple and puts it in a webUI as well. Includes working examples of SSH and API calls among tons of other things and deployable working apps in seconds. www.devnetui
