ACI Microseg - Cisco AVS vs. DVS
With respect to ACI and microsegmentation in a VMware environment, other than the OpFlex capability, what are the differences b/t using the AVS vs. DVS?
Can we get the same level of granularity w/ both AVS and DVS, e.g. OS, hostnames etc.?
Scott
Robert Burns
When dealing specifically with uSeg differences, they implement uSeg slightly differently.  vDS uses PVLANs, whereas AVS uses mac based EPGs for segmentation.   The differences are mainly under the hood.  The same level of granularity are available to both in terms of uSeg attributes.
Robert
Robert Burns
Robert
There is a scenario where the two differ greatly.  If you have a non-ACI leaf switch in the path between the ACI fabric and the VM Hosts then the AVS switch will be able to "tunnel" through that non-leaf node switch and still provide a end-to-end fabric experience (i.e. application-centric mode).  I've seen this when a data center has an existing VBlock implementation with N5Ks top of rack and is not able/willing to upgrade them to N9Ks.  By deploying AVS in the VM environment, ACI is able to maintain an end-to-end fabric view of the VM endpoints.  If you go with DVS for that scenario then the VBlock VM environment will need to be left in network-centric mode (along with every subnet/vlan that lives in that VM space).
Well it's not entirely correct. You can still segment a subnet in multiple EPGs if you have an intermediate L2 switching device between the fabric and the hosts. EPGs are identified by VLAN and subnet is completely abstracted. This means that you can have the same subnet carved up into multiple EPGs, therefore multiple VLAN. The extra step is just to configure these VLANs on the intermediate switch. If micro-segmentation is required, then this becomes cumbersome since you need to find a way to automate (preferably) the PVLAN configuration. There's no such thing as network-centric vs application-centric mode in ACI, only design choices against requirements.
Nicolas
