Event jabber angular2
mehdi.hajar3
I would like to know if we can use Jabber events (for example OnTelephonyConversationStateChanged) with angular2 and how?
I tried to write a function but it doesn't work :
OnTelephonyConversationStateChanged(json:any):void{
     //do something
With simple javascript it worked:
function OnTelephonyConversationStateChanged(){
     //do something
Thanks for your help
npetrele
Angular2 is javascript, correct?  I don't know anything about angular2, but if it's javascript, there is probably a way to accomplish what you're trying to do.  But, regretfully, I can't help you.
