iOS ACBClientSDK - AudioManager speakerphone - too low volume
is it possible to set volume to phone.audiomanager in code ? Becaouse it is too low and I can't hear other side.
When I use headset and change audiomanager to headset volume is perfect.
iPhone is set to maximum volume. And in code AVFoundation is also set to max volume
and I also override hardware to use speaker and it dosen't work.
Matous
Hi Matous,
Are you running with REM 11.6(1)_ES4 which has been tested as fixed for your initial issue?
Rob
9 Replies 9
robdoyle
Hi Matous,
I assume your referring to the ACBAudioDeviceManager, which allows the app to select the audio output device.
Are you calling [phone.audioDeviceManager setAudioDevice:ACBAudioDeviceSpeakerphone], and finding the volume to be too low?
We don’t offer an API to set the volume, we just rely on the system volume controls.
I’m not clear on what you mean by:
  • And in code AVFoundation is also set to max volume
  • I also override hardware to use speaker and it doesn't work
Can you clarify exactly what you did?
Rob
Hi Rob,
once again I need your help .
Code to call AudioManager:
        // audio manager
        self.phone?.audioDeviceManager.start()
        self.audioSession = AVAudioSession.sharedInstance()
        var pointer:ACBAudioDevice?
        // is headset plugged in
        if (Common.instance.isHeadsetPluggedIn()) {
            pointer = ACBAudioDevice.wiredHeadset
            self.phone?.audioDeviceManager.setAudioDevice(&pointer!)
        } else {
            pointer = ACBAudioDevice.speakerphone
Register observer for plugged headset:
        observer = NotificationCenter.default.addObserver(
            self,
            selector: #selector(CallController.audioRouteChangeListener(notification:)),
            object: nil)
Observer notification function:
    @objcfunc audioRouteChangeListener(notification:Notification) {
        let audioRouteChangeReason = notification.userInfo![AVAudioSessionRouteChangeReasonKey] as! UInt
        switch audioRouteChangeReason {
        case AVAudioSessionRouteChangeReason.newDeviceAvailable.rawValue:
            if (self.phone != nil) {
                // set headset
                var pointer = ACBAudioDevice.wiredHeadset
                self.phone?.audioDeviceManager.setAudioDevice(&pointer)
            break
        case AVAudioSessionRouteChangeReason.oldDeviceUnavailable.rawValue:
                // set speaker
                var pointer = ACBAudioDevice.speakerphone
                // override speakerphone to be the one
                try! self.audioSession?.overrideOutputAudioPort(AVAudioSessionPortOverride.speaker)
            break
        default:
            // not need to be implemented
            break
I use swift. It works perfectly in all other things so I assume that is no problem in using Swift. The "audioDeviceManager.audioDevices()" return array with one item.
Hi Matous,
Please print out the value of "audioDeviceManager.audioDevices()" when the headset is not plugged in and then when it is plugged in.
After this print out [uc.phone.audioDeviceManager selectedAudioDevice];
Rob
Hi Rob,
when headset is plugged in
audioDeviceManager.audioDevices() {
     0,
audioDeviceManager.selectedAudioDevice(): nil
when headset is not plugged in
Matous
Hi Matous,
Your results don’t make much sense to me:
a) I don’t know why there would be duplicate values in ‘audioDevices()’
b) I don’t know why ‘selectedAudioDevice()’ would return nil.
I'll have to raise a bug internally.
What device and iOS version were you testing on?
Rob
Hi Rob,
iOS version is 11.1.1
iPhone is iPhone5s
Matous
I tried patched version of ACBClientSDK for sound form the speaker.
And I have one problem.
For the first time when app is launched. The first call audio is not form the speaker. Other calls works perfectly
When in the first call headphones are plugged in and out the audio is from speaker.
But the first call audio is always from ear-speaker.
I changed the order of "setAudioDevice". And I called them all when call was connected and nothing worked.
Do you have any idea that might help ?
Regards.
Matous
Hi Matous,
Rob
Hi Rob,
I used REM 11.6.1.10000-7-ES2 from Dec. 22, 2017 found on URL: developer.cisco.com.
Thank you. I'll try ES4
Matous
