04-09-2015 01:21 PM
Hello. I'm using the Postman extension for Chrome to test the Jabber Guest API. I'm new to Postman, so perhaps I'm doing something wrong, but under the Basic Auth tab I enter my username and password, click Refresh Headers, then I enter the request URL and click send. Each time I get a 401 authentication error. However, if I log into the web interface of the Jabber Guest server (using the same username and password), then send the request again it works just fine. Am I doing something wrong?
Thanks, Mike
04-09-2015 03:20 PM
You'll have to explain what it is you're trying to do with REST, and it would help if you could include the data you're sending with the request.
04-09-2015 05:49 PM
At this point I'm just trying to explore how to use a REST API and just do some very basic things. So to test I'm simply using the Postman extension for chrome to send the URL https://[IP address]/cjg-api/rest/links/ in order to get back a listing of all configured links. As I mentioned, if I log in to the Jabber Guest server admin page, then make the request, I get back data. But If I'm not logged in, even though I am including the basic authentication info in the request header, I keep getting an error.
04-13-2015 09:30 AM
Did you do this? (Copied from the documentation):
The first time that you sign in to Cisco Jabber Guest Administration, you must change your password. If you have not yet changed your password through Cisco Jabber Guest Administration, you must change your password the first time that you access the API.
04-13-2015 09:42 AM
Yes, I have changed the password.
04-13-2015 12:10 PM
I'm coming up blank, then. If you're doing a GET, your URL looks like this: /cjg-api/rest/links?limit=10&offset=0 , and you are using the correct username and password, then it should work. The only other thing I can imagine as a possibility is that you haven't told Chrome to accept the certificate for the server.
04-18-2015 05:33 AM
Has anyone on this forum tried using Postman with the Jabber Guest API?
